Hardwiring my radar detector, different approach??
Old 01-31-2009, 11:39 PM
Renegades's Avatar
Renegades is a glorious beacon of lightRenegades is a glorious beacon of lightRenegades is a glorious beacon of lightRenegades is a glorious beacon of lightRenegades is a glorious beacon of light
Thank you very very much, I will report back
Old 02-01-2009, 09:10 AM
WOODTSTER's Avatar
I am going to try this also, The V1 coil cord makes my otherwise cool looking
interior, very cheesy.
thanks,
MK
Old 02-01-2009, 10:02 AM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
If you guys are nervous...a stereo shop could do this in about an hour..they are about 35/hr here....
I plan to go in and get a slightly longer cable in the future....probably in a year or so. It worked right out of the box. I confirmed my wire choices via a TSB on renntech.org for the autodim mirror....generic 996 TSB as it comes standard for our turbos. There is a 997 thread with this on rennlist (orange/black for + and brown for ground). FYI if you have 997's.
Oh, the final piece to the puzzle for me as ditching the escort mount. Great detector (iX)...lousy suction cup solution.
I got this:
http://www.southernmustangparts.com/...unt-p-414.html
It is superb. What Escort should sell out of the box. No more worries about a dented leather dash or broken detector...
JB
Old 02-02-2009, 03:06 AM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
thanks,
Agreed! Finally why I had mine hardwired and moved up to the top.
MK
I got this:
JB
Pretty cool.. do you know if this will fit the V1?
Old 02-02-2009, 06:46 AM
I don't know. I think the power cords are similar. I don't think the mounts are....but I would have to defer to a person with a V1.
I don't have a V1...iX....
It is amazing what you can find with google...how I found the mount for the escort/bel units I pasted above.
All I found for V1's were nice mirror mounts...but the 996TT mirror may not be the best to clamp...
Best!
Jeff
Old 02-03-2009, 12:50 AM
flash68's Avatar
Best!
Jeff
Google? what is that?
thanks, I will look into it.
Old 02-03-2009, 05:13 AM
One could take this mount and probably (note uncertainty) modify it to work with a V1. It had two holes in it and some push type connectors for the escort connector. One could get it, cut those, and in theory take a VI mount gadget and adapt the things to work together. Probably about 15 minutes with some tools and some flat black paint.... Probably what I would do....if nothing else is out there. This thing is rock solid. Much better than the joke escort unit that comes in the box.
JB
Old 01-23-2010, 08:58 PM
gnewhouse's Avatar
gnewhouse has a spectacular aura aboutgnewhouse has a spectacular aura aboutgnewhouse has a spectacular aura about
Anyone doe this with a V1 yet?
If so, pls share!! Thx in advance.
Old 01-25-2010, 05:15 PM
PAULUNM's Avatar
PAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to allPAULUNM is a name known to all
Newb question here- any tips in removing the map lights or the sunroof control panel? I'd hate to break something...
Old 01-25-2010, 06:10 PM
gnewhouse's Avatar
same here (newb that is)... seeking words from the wise and experienced pls, thx in advance.
Old 01-26-2010, 07:46 AM
function12's Avatar
function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !function12 Is a GOD !
I used the phone connection down by the radio to hard wire my V1. RennTech has a pretty good write up.
Old 12-21-2014, 07:13 PM
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
Anyone tie the v1 or other detector into one of the OEM dash switches? This was my intention until I realized all the buttons/switches are momentary switches. I need one that is on/off until I push the button again (unlike a garage door button)? I took apart one of the OEM switches haven't figured a way to modify it.
Old 12-21-2014, 07:29 PM
32krazy!'s Avatar
why do you need an on / off? i use a momentary targa top switch. works like a charm. hit it either direction and the door opens hit it again door closes
Old 12-21-2014, 07:36 PM
BMiller33's Avatar
It's not for garage opener it's for V1. I want ability to switch on or off.
Old 12-22-2014, 02:26 AM
32krazy!'s Avatar
duh guess i should read better! mine is wired to the dome switch it goes on when i turn the key and off the same way
Quick Reply: Hardwiring my radar detector, different approach??
