Install Pics of Intercoolers, Headers, and Intake
oops I missed that. Well these are definitely better then the stock IC and the GT2 IC as everyone here says are not that much better. The specs on the Agency Power intercoolers are:
Dimensions:
-Core Thickness: 3.5 inch
-Core Volume vs. Stock: 40% larger
-Performance Efficiency: 85%
-Flow rate: 620 CFM / side
-Leak Tested: @ 30 PSI
-Pressure Drop: less than 1%
-Support HP: 750+
Dimensions:
-Support HP: 750+
Dimensions:
-Support HP: 750+
Dimensions:
-Support HP: 750+
And have you guys done testing to compare iat deltas on various turbo set ups?
Curious how much impact bigger ICs make on these cars....
Thanks for the info!
that is the data compared to the stock... here is a real world test for you. do 1/4mile, 60-130, and dyno with your stock IC's. I will send you the AP intercoolers at a special price. Install them and do all the same tests. If you like them, cool, if not, take them off and send them back for a full refund.
I do not have AP intercoolers, because they were not around when I bought mine, but I have B6 ones. I came from stock 996TT intercoolers on my GT3071/K24 setup (at the time, now they are 3076's). I do not have any dyno or 60-130s, but I do know that the car did feel slower on the summer days with the stockers after 20min of driving and beating on the car. With the new intercoolers I hardly notice any heat soak, if any. That in my opinion is the biggest problem with stock ones.
If I didn't have B6s I would have the AP ones in a heart beat.
Jun 10, 2017 07:45 PM
ECS Tuning - VW
Aug 21, 2015 09:11 AM
ECS Tuning - VW
Aug 19, 2015 08:58 AM
Rep points for you.
