Transmission Removal with engine inplace
Old 11-08-2010, 10:29 PM
QMQ668's Avatar
QMQ668 is on a distinguished road
need to know what what
Have to replace clutch disc on my 2007 GT3RS
Have taken some shot's and would dearly like to know what these parts are and if/how they are removed.
Old 11-08-2010, 10:32 PM
QMQ668's Avatar
more images
Old 11-08-2010, 10:36 PM
QMQ668's Avatar
and again
Old 11-08-2010, 10:39 PM
QMQ668's Avatar
Last set
Old 11-09-2010, 10:10 AM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
QMQ search around for a copy of the factory service manual it should walk you right through this process bolt by bolt essentially, but it should not be dramatically different then this write up except for no front drivetrain.
Old 11-09-2010, 09:55 PM
QMQ668's Avatar
How can i get my hands on such manual? any pointers.
Old 11-10-2010, 05:58 AM
i would search the gt3 forum, look on ebay they are usually on there and on rennlist ill dig around see if i can find one.
Old 11-10-2010, 07:55 AM
Old 11-10-2010, 03:30 PM
QMQ668's Avatar
all manuals seam to be for 996, but is there any change in the 996 and 997?
Old 02-23-2018, 03:43 PM
jadkar's Avatar
jadkar is an unknown quantity at this point
Doing a little grave digging here.....
Have to do a clutch on a 997.2 turbo and I'm wondering if these instructions can be used.
I understand they are completely different engines but wondering if this can at least be used as a "guide".
If not does anybody has link to instructions.... writeup... video... anything? Tried looking for a shop manual online and ebay and couldn't find one.
Thanks in advance!!
Old 03-03-2018, 06:09 PM
fpb111's Avatar
fpb111 is on a distinguished road
Get an engine support bar. Sir p254 for when you remove the trans.
http://www.autotoolworld.com/Sir-Too..._p_205929.html
Or here
https://www.usatoolwarehouse.com/usa...iABEgLn2PD_BwE
Old 03-04-2018, 05:53 PM
jadkar's Avatar
Or here
I have the trans out but it was a PITA. Everything was super straight forward until I got to the clutch fork pin. That by theory was easy but the execution (getting your tools in that little space) really sucked. Other problem I ran into was the car height on my lift compared to how high my trans jack could reach. I have a lift but couldn't lift the car too high or else my trans jack couldn't reach the car. At maximum reach of the trans jack the car was not high enough to get the trans out when I lowered the jack. make a long story short what I need to do is get the engine support bar like you mentioned. Then I could remove my super big jack stands from the equation. Once I have that then I'm going to buy a lifting table, remove the wheels from my trans lack and racket strap it to the top of the table. This will allow me plenty of adjustability in height while the bar will support the engine.
I want this flexibility because I have a feeling I'm going to be in for a real treat while trying to put the clutch fork pin back in
BTW.... Chatam is in my backyard. You feel like renting me your engine support bar??
ID:	521782   Click image for larger version
ID:	521783   Click image for larger version
ID:	521784   Click image for larger version
ID:	521785   Click image for larger version
Old 03-13-2018, 07:11 PM
fpb111's Avatar
Put it back in yet?
Old 03-14-2018, 08:18 PM
jadkar's Avatar
Put it back in yet?
Yup.... check my other thread
Old 03-21-2018, 11:01 AM
BMiller33's Avatar
BMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond reputeBMiller33 has a reputation beyond repute
It's a FN nightmare, esp w/o a lift. Save yourself a headache and a lot of time and drop the motor is my advice for anyone reading this. The entire process is much cleaner, better, and you can pin your lines while you're at it.
Oh, did I mention It's a FN nightmare, esp w/o a lift?
04-28-2022 12:38 AM
09-01-2015 03:16 PM
The Oss
08-24-2015 08:19 PM
JMon
08-21-2015 08:20 AM
ECS Tuning - BMW
08-19-2015 09:29 AM
Quick Reply: Transmission Removal with engine inplace
