ECU reflash on tiptronics
Old Feb 22, 2009 | 10:43 AM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
Do you guys think that reflashing the ecu would change the way a tiptronic shifts? shift points..etc? Maybe some ecu programmers can chime in here...
thanks
Old Feb 22, 2009 | 06:50 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
I don't think my current map changed the shift points. I will ask my tuner.
Old Feb 22, 2009 | 06:55 PM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
thanks
This is done in a sepate control module from the main engine DME.
We do this in the Audi market, but have not tackled this in the 996tt world.
Is this something you guys feel would be useful?
Old Feb 22, 2009 | 07:13 PM
I notice under WOT my shifts are around 6500. Maybe if it held on a little longer it would be better.
Old Feb 22, 2009 | 07:22 PM
derm's Avatar
derm is infamous around these parts
Yes, to me absolutely!
Old Feb 22, 2009 | 07:55 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
I think shifting from 6500 to 7000 would be very useful for tip-users
Old Feb 23, 2009 | 12:41 PM
boca996tt's Avatar
I would like the problem soughted out about flooring from a dead stop.. and its not that fast as at partial throttle... and I would like the shift points to shift harder if possible.. EPL do you think you can tackle the problem for us tipsters?
Old Feb 23, 2009 | 08:21 PM
silver's Avatar
silver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to allsilver is a name known to all
I too would be interested in crisper shifts for the tip. I would not want to accelerate the wear to the unit or removethe way power is halted briefly the shift is executed cleanly. Just needs to be a bit crisper and quicker.
Old Feb 24, 2009 | 07:20 AM
dublinoh's Avatar
dublinoh is infamous around these partsdublinoh is infamous around these parts
I would like it to default to 1st gear when you stop. 2nd gear starts are the norm if your are full auto unless you really stomp it. It has plenty of torque for a 2nd gear start but it places the car into the 2300 to 2600 rpm range more and this is the high "drone" or harmonic area of the exhaust note. It would be awesome if you could give us 2 or 3 modes that were selectable. Stock/performance (just the 1st gear start)/high performance (hold gear to higher rpm before shift up and more aggressive shift down). I would need more info before I agreed to a higher rpm (6500 to 7000) shift point relative to wear or possible failure.
Old Feb 24, 2009 | 07:43 AM
MY996TT's Avatar
MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !MY996TT Is a GOD !
I have no complain about my Tip. One area to be improved is the down shift in auto mode. If the car can down shift when it's below xxxx rpm, that will be good.
Old Feb 24, 2009 | 08:05 AM
Webtool1's Avatar
Webtool1 is infamous around these partsWebtool1 is infamous around these parts
+1
would really like selectable modes and less time in the drone zone.
Old Feb 24, 2009 | 10:37 AM
alex55's Avatar
alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !alex55 Is a GOD !
I really like my tip and i don't have any complains !
Old Feb 24, 2009 | 07:36 PM
sweeney186's Avatar
sweeney186 is infamous around these parts
I would really like to get quicker shifts-up & down
Old Feb 24, 2009 | 07:45 PM
ttboost's Avatar
Get a 6 speed!! J/K...
COBB Tuning
Nov 3, 2015 08:39 AM
Needsdecaf
Cayenne 958
10
Oct 12, 2015 03:05 AM
Oct 2, 2015 02:23 PM
alpha motoring
Oct 2, 2015 12:04 PM
