Pics of my ol tires... (extreme stretching)
Old Mar 2, 2009 | 11:17 AM
angldrkns9's Avatar
angldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud ofangldrkns9 has much to be proud of
yo steve, your tires look too narrow for your wheels
what condition were the turbo twists in when you picked them up?
Old Mar 2, 2009 | 11:23 AM
996TT_STEVO's Avatar
996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute996TT_STEVO has a reputation beyond repute
That 3rd & 4th pics... the tire bead is not even mounted onto the lip... that is seriously dangerous!!!
Old Mar 2, 2009 | 11:27 AM
I'm not trying to be funny here... whoever mounted these needs shot
Old Mar 2, 2009 | 11:39 AM
iLLM3's Avatar
That's what I told him last night, those tires under load/turns were probably shifting inside of the rim!
Old Mar 2, 2009 | 12:33 PM
DNugget991GT3's Avatar
im thinkin to put 335 30 19s
if i remove all the rear fender lining (both inside and out) will it rub ?
Old Mar 2, 2009 | 12:42 PM
Tonk's Avatar
Tonk has much to be proud ofTonk has much to be proud ofTonk has much to be proud ofTonk has much to be proud ofTonk has much to be proud ofTonk has much to be proud ofTonk has much to be proud ofTonk has much to be proud ofTonk has much to be proud ofTonk has much to be proud of
That's not an extreme stretch...
Old Mar 2, 2009 | 01:00 PM
VIPModular's Avatar
VIPModular is infamous around these partsVIPModular is infamous around these parts
Originally Posted by STEVE KOJASEVIC
dude
no one knows
not even i-forged themselves ...
I'm not trying to start anything here, but shouldn't the manufacturer know what width the wheels are? Measure from the inside the rolled or edge portion of the wheel to the other side to the same spot...that should give you your width.
Old Mar 2, 2009 | 01:17 PM
Turbo Fanatic's Avatar
Did you meaure the outside of the rim or the inside?
wheels are measured inside the lips from bead seat to bead seat. The lips typically aren't as thick as they are tall, so an 8" width wheel will measure at 8.75" or so from outside edge to outside edge.
Originally Posted by NineNineSixTT
I don't think wheel widths are that simple.
A while back, i needed to order a wheel. I measured the width, it was a tad over 12". When i brought the wheel in to order an exact copy, they told me even though i measured it to be over 12", it was a 11.5" wheel.
Old Mar 2, 2009 | 01:25 PM
does anyone have pics of their 19" iforged wheels ?
i'de like to see how the tire sits...
Old Mar 2, 2009 | 02:21 PM
confirmed with I-Forged..
it's a 19x12
and im being told that the michelin being stretched like that is fine...
Old Mar 3, 2009 | 02:37 PM
Jedidiah's Avatar
Jedidiah is infamous around these parts
not that you need further confirmation, but the tire stretch is fine. I daily on stretched tires that would make those look conservative and I drive 2500 miles a month.
Stretched tires being dangerous is simply a misnomer.. I know many guys who run stretch setups without any problem.
Old Mar 3, 2009 | 04:52 PM
Alpental1's Avatar
Alpental1 is infamous around these parts
That's unbelievable. Send your pics to Geoff at Seattle Wheel Service for a professional opinion... seattlewheel.com, perfection@seattlewheel.com
Old Mar 3, 2009 | 05:22 PM
Neil A's Avatar
Neil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud of
Stretch is ok for slow and show but i would not be running tires like that on a high performance car like a 996 tt.
Old Mar 3, 2009 | 06:31 PM
NMT's Avatar
NMT
NMT is a splendid one to beholdNMT is a splendid one to beholdNMT is a splendid one to beholdNMT is a splendid one to beholdNMT is a splendid one to beholdNMT is a splendid one to beholdNMT is a splendid one to behold
THAT DOES NOT LOOK SAFE. what are the offsets?
Old Mar 3, 2009 | 06:53 PM
nick
im not sure what the offsets are...
the hub had to be extended an extra 3mm to clear my stoptechs
what about the first pic, the michelin ps2 ..
do you sell 19x12 wheels ?
does a michelin ps2 fit differently ?
