Evo gt 700 not making boost
Old Mar 4, 2009 | 05:18 PM
strincon's Avatar
strincon is infamous around these parts
I wanted to ask what other 996tt evo gt700 out their are making for boost. I only make .9 bar. Evo sais i should make 1.4-1.5 bar and i have a boost leak. I had the car checked for any leaks and it does not apear to have any leaks. My boost gage is correct. Evo sais i still might be one of the vacum lines on the deverter valves. It is not throwing any codes and it runs fine just missing 80- 100 Hp.
Any ideas and what other gt700 owner have expierenced will be much appreciated.
Thanks Scott
Old Mar 4, 2009 | 07:05 PM
NineNineSixTT's Avatar
NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !NineNineSixTT Is a GOD !
Thanks Scott
I've had hoses that blew off to the point my car only ran .7 and .8, in that case i heard a obvious sound that indicated there was something wrong. When you are on WOT, can you hear a swooshing of air?
Old Mar 5, 2009 | 09:13 AM
s14roller's Avatar
s14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to behold
What are you pressurizing the system when you are checking for boost leaks? I have heard even though most test it at a normal psi 15-20psi, true leaks can be found if you pressure the system to like 30+psi…
Old Mar 5, 2009 | 09:18 AM
unvmy996's Avatar
indeed you ned to test at the turbos at 30 psi.
Jul 29, 2019 11:13 AM
R/TErnie
New Member Introductions
Sep 2, 2015 04:36 PM
TrackOne
Aug 20, 2015 12:56 PM
Wheel Experts
American Muscle
Aug 19, 2015 09:07 AM
Wheel Experts
Wheels/Tires
Aug 19, 2015 09:05 AM
