waste gate springs
Old Mar 7, 2009 | 11:49 AM
K24F's Avatar
K24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond reputeK24F has a reputation beyond repute
waste gate springs
Hi guys!
Little problem with my tuned TT (560hp/800Nm):
When cold weather (5°C) and especially since I got big intercoolers, my waste gates (on my K24's) do not keep the pressure on last gears. (even by 12°C with the IC's)
I checked my WG springs with a Mytivac pump: 0.3Bar starting opening and 0.7 fully open; I modified with the nuts and now 0.5bar starting opening but still 0.7 fully open and same...
Do you think I need hard WG springs (1.0bar) sold by Evoms and others or the problem is somewhere else?
(my boost pressure is 1.2bar)
Thanks for your advices!
Pascal
Old Mar 7, 2009 | 11:58 AM
unvmy996's Avatar
i would get the 1 bar springs yes .
Old Mar 7, 2009 | 05:26 PM
K24F's Avatar
In fact the car goes, but when full gas in 6th for example, it stops to take revs and I can hear a sound like "FLPFLPFLP" like an exhaust leak, I cut a little throttle and it runs again...
But never when 20°C and more.
The boost is Ok, 1.2bar, but sometime does not hold : "FLPFLPFLP"?
The Ecu is good (Sportec) and the WG are K24's stock, normal?
thx
Old Mar 7, 2009 | 05:34 PM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
FlpFlpFlp? Or is it PlfPlfPlf? Press one for english.....
If you're running stock springs, you definitely need the upgrades. I got mine from UMW and the car grabs and holds 1.2 bar when I get on it. Upgraded springs are one of the cheapest and best upgrades you can get for your car. Under $300 for the setup....but then you have to cut open your actuator cans and install the springs...not rocket science, but not for a novice either.
We do not have the temperature deviations you have....so I can't address what your temperature extremes might be doing.....but Kevin or Tony can probably add their expertise to the mix.
Old Mar 7, 2009 | 05:35 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Yes,you need them...for sure...otherwise get a boost controller...
Old Mar 8, 2009 | 03:34 AM
K24F's Avatar
"Flpflpflp"!
Ok, so where can I order those parts? I only know Evoms, but Chuck you speak about less than 300$, where?
And who are Tony and Kevin, sellers?
Will it be definitely finished with "Flpflpflp"?!
Thx
Old Mar 8, 2009 | 09:08 AM
Cascade's Avatar
Cascade is infamous around these partsCascade is infamous around these parts
I have the same question, who sells 1 bar WG Springs? They shouldnt be that expensive. Can I pull them from an aftermarket wastegate like synapse or Tial?
Old Mar 8, 2009 | 09:14 AM
unvmy996's Avatar
protomotive , Ultimate motor works , evo ms, alot of people have them.
Old Mar 8, 2009 | 10:23 AM
I got mine from UMW...as you can see in my signature block...
Old Mar 8, 2009 | 01:46 PM
K24F's Avatar
I have a question:
If you have stock ECU and bolt hard WG springs, you get a little more boost that the stock program allows: Gain.
If you have stock WG springs and 1.2Bar ECU, would you get more than 1.2Bar with the special WG springs or will it help your WG to hold better this pressure?
Because my need is not more pressure, it is only holding the pressure waited by the ECU to enjoy my car "safely".
Thx specialists!
Old Mar 8, 2009 | 02:01 PM
K24F's Avatar
I checked the UMW website but the site does not allow to order?
Old Mar 8, 2009 | 04:37 PM
unvmy996's Avatar
call kevin directly .
Old Mar 8, 2009 | 10:39 PM
Contact for Kevin....
OR.....you can email him at kevin@ultimatemotorwerks.com He usually stakes out his incoming email and jumps right on any questions you might have.
Old Mar 12, 2009 | 05:55 AM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
All I need is the 2 springs, No hardware, does anyone know where I can get 1 bar springs from for K24s. I cannot seem to find any on the web, only the full kits.
SWR
Old Mar 12, 2009 | 08:36 AM
I switched out the wastegate springs on my X50 for the UMW wastegate kit and left the springs at Adam's garage....you might try giving Adam (that's his calll sign on Rennlist) a PM and see if he's still got them. I dont know if they're 1 bar springs...but they were the stock 02 X50 springs.
ELMEL
Sep 28, 2015 01:12 PM
xbox_fan
Sep 13, 2015 01:25 AM
K24F
Sep 12, 2015 02:55 PM
ModBargains
Sep 12, 2015 12:55 PM
