996 GT2 PCCB discs
Old Mar 10, 2009 | 08:46 AM
Y65MPH's Avatar
Y65MPH is infamous around these partsY65MPH is infamous around these parts
Old Mar 10, 2009 | 11:09 AM
SXN's Avatar
SXN
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
They should last much longer than 27k... try talking to the service manager there??
Also, how can you tell if it's a 1st gen or 2nd gen style?
Old Mar 10, 2009 | 05:19 PM
GT2CS's Avatar
GT2CS is infamous around these parts
1st gen were on all GT2's up to 2004. I agree 27k is really low. The frront pads were changed at 21,000 ie 6000 miles ago and no mention was made that the rotors were worn. So they have gone from 'normal' to need replacement in 6000 miles! Something aint right!
Old Mar 10, 2009 | 05:26 PM
GT2CS's Avatar
Originally Posted by Y65MPH
Thanks. Looks interesting, but can these are steel rotors. Can you run PCCB rears and steel front rotors? Also why have my fronts deteriorated so muuch whilst the rears are fine??????? Doesnt make sense.
Old Mar 11, 2009 | 08:22 AM
NY-GT3's Avatar
NY-GT3 is infamous around these parts
Looking for Ceramic brakes for my 996 GT3
Any leads would be appreciated.
Thank you,
-Randy
rhjp@yahoo.com
Old Mar 11, 2009 | 08:24 AM
NY-GT3's Avatar
PCCB Question
Is there a difference between the PCCB’s used in the 996 GT2 and the 996 GT3?
Thank you,
-Randy
Old Mar 11, 2009 | 01:20 PM
oak's Avatar
oak
no, both are gen 1.
Old Mar 13, 2009 | 04:18 PM
GT2CS's Avatar
so if i were to switcch over to steel rotors, what system would you recommend for my 2002 GT2? What diference is their in unsprung weight for PCCB v steel
Old Mar 15, 2009 | 03:51 PM
Bleu Omdurman's Avatar
Bleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond reputeBleu Omdurman has a reputation beyond repute
I'd imagine that having PCCB in the rear and steel fronts would change the handling under heavy braking. I'd imagine more breaking force at the rear which would make the rear a bit tail happy.
If you switch to steel fronts, I'd do the whole car. I'd also think about selling your rear PCCB's to off set the cost if that is important. You might also hold on to the rears in the event that you decide to sell the car. THat way you could just buy the new fronts and the car would have all PCCBs which would help the value.
Also, you mentioned that you had the pads changed 6000 miles ago and now your front rotors are chewed up. Did the shop put the correct pads on? If not, they might owe you a set of rotors and pads now, let alone free labor to bolt it all up.
Old Mar 16, 2009 | 03:34 PM
GT2CS's Avatar
Been looking at this post on stuttgart9
http://www.stuttgart9.co.uk/upload/p....php?t=5&pp=40
And one of their users has successfully litigated or convinced Porsche GB to give him a set of new PCCB's for his GT2 due to premature wear Check out how Porsche marketing of the PCCB's changed after they had a host of problems with the Gen 1's!!! So watch this space.
I even had my car MOT'd (thats a UK roadworthiness test carried out every year after the car is 3 years old) in July 2008 and they never picked up on any damage to the rotors and the car has been off road since October 2008 - so its hardly been used and they have pitted all on their own. Here's what I intend to do. As a number of guys have been running steel GT3 cup rotors up front and keeping the rear PCCB's, I shall buy a set of GT3 cup rotors and do a straight swap (Euro 568 delivered per pair). Here's the quote from Gert Carnewall who sells the rotors and loads of Porsche tuning parts:
The GT3 cup rotors are a straight replacement for the front pccb rotors.
A lot of drivers use the steel ones in the front and keep the pccb's in the rear as these don't wear as fast.
Andrew
Old Mar 18, 2009 | 06:41 AM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
What the PCCBs on the 2005 Turbo "S" Gen I or II?
SWR
Old Mar 18, 2009 | 07:17 AM
GT2CS's Avatar
must be Gen 2 as the 2004 GT2 has the Gen 2
Old Mar 18, 2009 | 09:05 AM
Are Gen II any more reliable? I was considering replacing them with steel while they were good and selling them. as long I can keep my calipers.
SWr
Old Mar 18, 2009 | 11:06 AM
9Eleven's Avatar
9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute9Eleven has a reputation beyond repute
No, Gen II's started with the '05 Turbo S.
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 25, 2015 03:27 PM
PelicanParts.com
996 Vendor Classifieds
Aug 20, 2015 02:41 PM
PelicanParts.com
996 Turbo Vendor Classifieds
Aug 20, 2015 02:40 PM
PelicanParts.com
Aug 20, 2015 02:37 PM
PelicanParts.com
Aug 18, 2015 03:42 PM
