Replacing Front Sway bar question
Old Sep 30, 2004 | 11:12 PM
BartN (TX)'s Avatar
BartN (TX) has a spectacular aura aboutBartN (TX) has a spectacular aura about
I'm thinking of replacing the stock front sway bar on my 01 tt. Replacing the rear with a GT3 adjustable was a 15 minute breeze, is the front as easy? Does the front GT3 bar fit? Is it also adjustable?
TIA,
Bart
Old Oct 1, 2004 | 12:19 AM
john stephanus's Avatar
john stephanus is infamous around these parts
It will fit if you use the curved drop links that are available from TRG for example.
Old Oct 1, 2004 | 07:12 AM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
I'm curious why you would want to replace the front........have you already done the back?
Old Oct 1, 2004 | 09:13 PM
BartN (TX)'s Avatar
Yes, I installed the GT3 adjustable rear sway bar a couple of months ago. I'm about to install the PSS9's and I thouht that I might as well get everything done at the same time.
Old Oct 1, 2004 | 09:43 PM
I think you will find the addition of the front bar to be valuable. Most folks seem to run the rear GT-3 bar full stiff to lessen the understeer and then do some tuning to the handling by adjusting the front bar.
Old Oct 1, 2004 | 10:01 PM
dwishen's Avatar
dwishen is infamous around these parts
Hi John,
Off-topic, but I see you are in Seattle.
So, do you have any firsthand (or even secondhand) experience with Speedware Motorsports? Are the reputable, honest, knowledgeable, etc.? I am considering purchasing some stuff from them (seats, maybe suspension). Any info. would be greatly appreciated.
Thanks,
David
Enemy
Nov 10, 2015 08:01 AM
r_matt_6
Oct 8, 2015 06:07 PM
TrackOne
Aug 20, 2015 12:56 PM
