996 Jacking Points Question
Old Mar 15, 2009 | 05:19 PM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
I understand about the 4 points by the wheels, this question is not about them.
I want to know if it is safe to put a piece of wood or a material softer than metal, and jack the rear of the car up by the cross brace between the engine and Gearbox just in front of the rear wheels? This will raise the whole of the rear of the car up so one can install axle stands on the 2 rear wheels.
While I am at it, is there a similar point to do the same to the front?
Thanks,
SWR
Old Mar 15, 2009 | 05:28 PM
GT3 Chuck's Avatar
Administrator
Old Mar 15, 2009 | 06:00 PM
Turbohead's Avatar
Turbohead is just really niceTurbohead is just really niceTurbohead is just really niceTurbohead is just really nice
No not the cross member. put the wood on the centerline of the engine case, where the oil drain plug is. Lift slowly and put the jack stands on the rear jack points car will be very secure.
Elliot
Old Mar 15, 2009 | 06:36 PM
Thanks that is just what I needed.
SWr
Old Mar 16, 2009 | 12:56 AM
ZIP22's Avatar
ZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond reputeZIP22 has a reputation beyond repute
Thanks,
SWR
If jackstands take to long to setup you can always get these...
http://raceramps.com/
I use them all the time!
Old Mar 16, 2009 | 12:48 PM
D_Nyholm's Avatar
D_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant futureD_Nyholm has a brilliant future
I actually did exactly what you were talking about this past week. That crossmember is very beefy and allows you to lift the car up so much higher as you don't have to worry about the engine mounts compressing and losing some of your lift. I was able to get my jackstands on their 4th stop with plenty more height to go, while using the engine i was only able to get it on the 2nd stop.
It sure worked for me and I watched it as it was lifted and used wood to spread out the load. Just because it worked for me doesn't mean it was right, but I had no problems at all.
Old Mar 16, 2009 | 01:43 PM
speedoflight's Avatar
speedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud ofspeedoflight has much to be proud of
also, use jackstand that have min height of 10ish". i have jackstands that 12" min height. it lifts the front too high and the rear would be sitting too low. i could not get the jack to slide in the rear.
Jul 29, 2019 11:13 AM
turbotuner20v
Sep 11, 2015 12:02 PM
gulf gt
Aug 27, 2015 10:27 AM
JMon
Aug 21, 2015 08:20 AM
