New car experience...
Old Sep 16, 2003 | 11:05 AM
Periokid's Avatar
Periokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud ofPeriokid has much to be proud of
Well I have had the turbo since last Friday. I have barely driven it since the weather has been less than ideal.
I got a chance to run for milk (just an excuse to go for a ride ) and as i SLOWLY pulled out of the local Dairy Barn, the front scraped (or is it scrapped?) the street surface. What an awful sound. Upon inspection it is ok. The very bottom is scraped. It is not visible. I guess this is one item that will inevitably get abused.
Old Sep 16, 2003 | 11:07 AM
JASCLASS's Avatar
JASCLASS is infamous around these partsJASCLASS is infamous around these parts
You can take light sandpaper to the bottom of the OEM front spoiler and sand it down to make it smooth again, just a tip.
Old Sep 16, 2003 | 11:08 AM
Periokid's Avatar
Thanks for the tip!! Ang suggestions as to the grit to use? Wet?
Old Sep 16, 2003 | 11:10 AM
JASCLASS's Avatar
Just a dry peice of light sandpaper does the job fine.
Old Sep 16, 2003 | 11:20 AM
Periokid's Avatar
Thank you. I will take care of it today.
Old Sep 16, 2003 | 12:18 PM
skaria's Avatar
skaria is infamous around these parts
Dude, get used to it. It is plastic for a reason... it will drive you insane if every time you scratch, you go try and fix it. I am just going to replace mine when it gets bad. If you do not drive it often, that's one thing... but I put about 20K/ year on my car. This is also the reason why I do not upgrade to the aftermarket front spoilers... I envy you guys in FL & CA where you can slam the car down, look awesome and not worry about destroying it. Whether you are in Philly, NY or Boston, the roads just plain suck. Driving here is like driving an autoX every day. And if its not the potholes, it just has to be the cobble stones. _All_ the roads around my condo and garage are cobble stones. I am just waiting for the day my car just gives up and falls apart. Thank goodness it is a lease.
COBB Tuning
Jan 1, 2025 09:02 AM
PorscheEnthusiast
Nov 13, 2015 02:23 PM
r_matt_6
Oct 8, 2015 06:07 PM
gulf gt
Aug 27, 2015 10:27 AM
Aug 21, 2015 09:56 AM
