If wheels aren't "Hollow Spoke", what are they, and where'd they come from?
Old Apr 3, 2009 | 03:06 PM
MarkP's Avatar
MarkP has a spectacular aura aboutMarkP has a spectacular aura about
I see a lot of references to Hollow Spoke OEM wheels. Therefore, I'm assuming there are some solid spoke wheels as well? Is that true? And if so, are those aftermarket replicas, or are those OEM ones from different years? If OEM, which years had Solid and which years had Hollow? I'm assuming Hollow are lighter and more desireable. What are the weight differences?
I'm buying a '04 996TT with OEM wheels that have been painted black. I prefer silver wheels, so I'd like to trade someone else for theirs, but I want to make sure I'd get equivalent wheels - only the color being different.
Thanks,
Mark
Old Apr 3, 2009 | 03:09 PM
Superfly's Avatar
Superfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant futureSuperfly has a brilliant future
IIRC 2001 TT's are solid. and GT2's in 12" rears (so wider), are solid.
Old Apr 3, 2009 | 03:10 PM
Ken's Avatar
Ken
Ken is a jewel in the roughKen is a jewel in the roughKen is a jewel in the roughKen is a jewel in the rough
If I remember right, all of the NB 996 came with solid wheels and the TT's/GT2's came with hollow
Old Apr 3, 2009 | 03:13 PM
dublinoh's Avatar
dublinoh is infamous around these partsdublinoh is infamous around these parts
They can also be "replicas"....usually described as "turbo style" wheels. Spokes are solid so heavier. Also the offsets can be different...may require spacers or just not fit.
MarkP's Avatar
Ok, so there's already some conflicting replies Is there anyway to tell from the wheels - are there different part numbers and do we know which is which?
Old Apr 3, 2009 | 03:28 PM
Superfly's Avatar
Again, if I recall, hollows have a 'rib' down the back center which the solids do not have. But it might be the other way around.
Old Apr 3, 2009 | 03:40 PM
heavychevy's Avatar
No, hollows look like they are hollow on the inside and have a smooth surface on the back of the wheel. Solids have the ribbed effect on the back of the spokes.
Old Apr 3, 2009 | 04:00 PM
MarkP's Avatar
Searching the for sale posts for photos turns up the following pics. I'm not sure if there's anything distinctive in these telling one way or the other?...
This one claimed to be hollow spoke from an '02 996TT:
Here was from a different post, but hard to see detail:
Old Apr 3, 2009 | 04:09 PM
dublinoh's Avatar
Mine are oem, they have the width left of the valve stem and offset right; raised on the front of the wheel.
MarkP's Avatar
Other info I found while searching:
Originally Posted by NineNineSixTT
Hollow Spoke Turbo Wheel
18x8 = 9.65kg
18x11 = 11.9
There is solid spoke and hollow spoke.
Solid spoke came on early model 01's and all c4s's. The rest of the turbo's got hollow spoke, which is suppose to be like 25% lighter.
Old Apr 3, 2009 | 04:15 PM
MarkP's Avatar
Also found this:
Originally Posted by gtr
I have two sets of wheel but I weighed the rear and they are the same weight but different design on back. Why? Both are for 996 Turbo and my orginal wheels are the hollow spoke. Are they two types of hollow spokes? Or are the weigh within 2-3lbs?
Originally Posted by iLLM3
The top with the grooves are not the hollow spoke wheels and weigh more then the bottom
Old Apr 3, 2009 | 04:16 PM
MarkP's Avatar
Originally Posted by Alan Baylis
Hollow wheels also always have metal valve stems where the solid wheels have rubber stems from the factory. Part numbers are as follows:
Early 2001 996 Turbo
8x18 50mm Solid 996.362.136.01
11x18 45mm Solid 996.362.142.10
Late 2001 and after 996 Turbo
8x18 50mm Hollow 996.362.136.04
11x18 45mm Hollow 996.362.142.03 and 996.362.142.11
2005 996 Turbo S (darker silver wheels)
8x18 50mm Hollow 996.362.136.32
11x18 45mm Hollow 996.362.142.32
Thanks!
Old Apr 3, 2009 | 04:39 PM
TunaRollZ's Avatar
TunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of lightTunaRollZ is a glorious beacon of light
ya. the ribbed ones are solid spoke. smooth is hollow spoke. unless they're reps...in which case they're probably all just heavy solid spokes.
Old Apr 4, 2009 | 12:51 PM
Seal Grey Matte's Avatar
Seal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to beholdSeal Grey Matte is a splendid one to behold
Bit more info to contribute. I was just swapping wheels and decided to weigh the stockers.
Rear hollow spoke w/ Sumitomo HTR ZIII's in 295 = ~58lbs
Front hollow spoke w/ Sumis in 225 = ~48lbs.
18" champion RG5 monos w/ Michellin Pilot Sports came in at 48lbs rear and 41 front.
I just shaved 35 lbs of unsprung weight in 20 minutes.
Old Apr 9, 2009 | 04:37 PM
ExclusiveTT's Avatar
ExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond repute
great info in this thread!
+1 rep to alan.
Mark, do you have any pics of your black wheels? I have two sets of silver one here (one of which I was planning on painting black to see how they look ont he car). I might be interested on trading if I could see what yours look like.
