PSM / Traction codes?
Old Apr 6, 2009 | 06:32 PM
horsepower1's Avatar
horsepower1 is infamous around these parts
Guys,
my '02 TT has both the PSM and ABS warning lights on. I have disconnected the battery a couple times, codes stay. I scanned the codes and cleared them, codes stay.
I really dont know what is wrong? nothing was wrong; i went and blead my spoiler actuators. In doing so i took the airbox out (disconnecting MAF). At first, i took the MAF back off and cleaned it with the aerosol clearner - looks fine. ever since messing with the actuators, i cant get the codes off?
what could it be?
Old Apr 6, 2009 | 06:37 PM
wross996TT's Avatar
Well...my advice is to get the codes read. Without them we will play 1000 guesses and you will spend a lot of $.
Old Apr 7, 2009 | 08:43 AM
sorry! forgot to add that yesterday. I had the codes read, it only had code P1250. we cleared the code, but the PSM/ABS light stayed on?
Old Apr 7, 2009 | 08:59 AM
wross996TT's Avatar
P1250 Boost Pressure Control Deviation - Above Limit
Possible fault cause
♦ Bypass flaps incorrectly adjusted
♦ Turbocharger faulty
I would look at the wastegates...they may be fouled or need adjustment. Also check for leaks/loose connections.
Clearing the codes if the fault is still present does not help...FWIW
Old Apr 19, 2009 | 08:18 AM
anyone have an idea?
BTW - the PSM/ABS lights came on as soon as i started the car, after bleeding the spoiler solenoids. Only engine thing i did was remove the airbox/maf, and reinstall.
there must be something going on here? it didnt overboost to set a code, all it did was start and idle. I have read that these two lights can come on as result of other codes/problems.
thanks
Old Oct 17, 2011 | 07:08 PM
boyg's Avatar
boyg is just really niceboyg is just really niceboyg is just really niceboyg is just really niceboyg is just really nice
This is what exactly happened on mine now, may I ask where did you find finally? Thanks
Old Oct 23, 2011 | 11:42 AM
boyg's Avatar
Mine intercooler hose loosen, fixed in half an hr...
Yogi911
Sep 9, 2015 08:20 PM
albert@velosdesignwerks
American Muscle Vendor Classifieds
Sep 9, 2015 04:21 PM
Other British Cars
Sep 9, 2015 04:18 PM
