1st gear rev limiter question
Old Oct 9, 2004 | 03:55 AM
4carl's Avatar
4carl is infamous around these parts
When I floor the GT2 in first gear it seems to hit the rev limiter at about 6200 not 6800. If i run it up easy in 1st it goes till 6800. In the other gears 2-4th it hits at 6800. What's happening? Is the tach not catching up to the motor? Has anybody experienced this ? thanks for the help. carl
Old Oct 9, 2004 | 05:29 AM
dbelleperc's Avatar
I soon will be a supporting member
dbelleperc is infamous around these parts
That is the case with the GT3's the tach isn't as fast as the engine, so even though it states 6200 it is really 6800.
Old Oct 9, 2004 | 06:27 AM
rmrmd1956's Avatar
rmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of lightrmrmd1956 is a glorious beacon of light
1st gear limiter is different than the rest
Old Oct 9, 2004 | 07:21 AM
4carl's Avatar
Has anybody else noticed this?
Old Oct 9, 2004 | 07:23 AM
dbelleperc's Avatar
In a tiptronic it is different, but not in a manual.
Old Oct 9, 2004 | 07:25 AM
Garey Cooper's Avatar
Garey Cooper is infamous around these parts
Different Rev Limit in 1st gear
The rev limit for first gear is lower than in the higher gears. And, I think this is a good thing! I've noticed it several times.
Old Oct 11, 2004 | 11:34 PM
Dock (Atlanta)'s Avatar
Dock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really niceDock (Atlanta) is just really nice
Re: Different Rev Limit in 1st gear
In a 6-speed the limiter is the same in all of the gears.
The problem with 1st gear is that the actual engine RPM and the analog cockpit RPM will not read the same when operating at or near WOT. The actual engine RPM is where the limiter is, and the cockpit analog gauge will lag considerably in 1st...so much that the engine is at redline when the tach reads 6000-6200 rpm. The rest of the gears don't create this problem.
Old Oct 12, 2004 | 12:05 AM
MKW's Avatar
MKW
MKW is infamous around these parts
Re: Re: Different Rev Limit in 1st gear
And if your car is chipped , the rev 6250 rpm limiter is sometimes hit when the slow-poke tach reads 5600-5800 rpm in first gear !
Old Oct 12, 2004 | 01:05 AM
Re: Re: Re: Different Rev Limit in 1st gear
The GIAC chip raises the redline, so it's easier to get more rpm on the tach prior to the engine's limiter.
I've seen 6400 rpm at WOT in 1st on a friend's Stage 2 without any limiter action.
Old Oct 12, 2004 | 01:11 AM
MKW's Avatar
MKW
Re: Re: Re: Re: Different Rev Limit in 1st gear
Originally posted by Ruiner
The rev-limiter is ~6750 and redline is 6500 in the 6spds.
Whoops - thanks for catching my typo. Meant " 6750 " .
Old Oct 12, 2004 | 01:14 AM
MKW's Avatar
MKW
Then what your friend's engine is really revving to and banging against is probably 7000 rpm or so , following this " lagging tach " thread .
Not interested in floating a valve in a car that is so short to begin with in 1ST gear - I prefer to keep the redline where it is stock. Change the gears, not the redline if you want more MPH in first gear .
Old Oct 12, 2004 | 02:37 AM
Re: Re: Re: Re: Re: Different Rev Limit in 1st gear
Hard to say. I did not hit the limiter with the tach at 6400 rpm, and EVO claims just a couple hundred rpm bump in redline. That bump may be just enough to allow the tach to catch up to the engine's new limiter.
Old Oct 12, 2004 | 02:40 AM
The redline on an '02 Turbo is 6600 rpm...
Old Oct 12, 2004 | 08:07 AM
cjv's Avatar
cjv
Moderator
The ECU limits first to 5900 rpm's. You see a little more because of the momentum getting there. If the redline was 6750 in first you would be up over 7100.
Old Oct 12, 2004 | 12:01 PM
MKW's Avatar
MKW
Chad , we had this thread going in the same direction about 18 months ago.
We all drove our cars slowly enough in first gear crawl to know that the limiter does allow 6700 rpm in that gear. Then someone said there are two ECU limits in first , depending on torque management .
So someone like Porsche PhD or Sol , what's the real deal ?
