KW3 Coils vs. PSS10's ...... School me.
Old Apr 16, 2009 | 07:22 PM
unvmy996's Avatar
D, from what i experienced and also heard that is a common problem with the bilsteins, i had the exact same issue and tried everything !! till i just swaped them out !
Old Apr 16, 2009 | 07:43 PM
mullynyc's Avatar
mullynyc is infamous around these parts
Larry-
I have an 02 as well and suspension is serious lacking on mine - only did the eibach springs. Car cannot handle the power. Unnerving to say the least. I am interested. Can you email me or ill email you. Not sure how that works here.
Old Apr 16, 2009 | 08:12 PM
dublinoh's Avatar
dublinoh is infamous around these partsdublinoh is infamous around these parts
I'm on pss10 and would not describe them as bouncy at all. With stock I could just about throw my Valentine 1 through the sunroof, the front was climbing and diving so much...pss10 solved this.
Old Apr 16, 2009 | 10:05 PM
ExclusiveTT's Avatar
ExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond reputeExclusiveTT has a reputation beyond repute
i am currently lookign to get a "budget" street suspension. After hearing negative reviews about h&r springs with stock shocks, I am leanin towards C/Os. It seems that the results are very spread among the same products... this is very difficult..
Old Apr 16, 2009 | 11:58 PM
Turbo Fanatic's Avatar
I have FVD Spec PSS9s. I believe they are virtually the same but with stiffer springs, similar to the RUF version of the PSS9s but without the price tag.
My understanding is that PSS9 to PSS10 are virtually identical.
My inclination when I got them was that the car rides smoother AND handles a LOT better.
The PSS9/10 series are known for having limited travel when really lowering the car, so if you are going to slam it, then look at other options where a stiffer spring rate and adjustable collars that will help give you that last 3/4 inch.
From my perspective, the car is as low as I want it. It's already hard not to scrape the front lip.
BTW the car is obviously rear heavy, so "slanting" a bit forward allows for both more travel in the rear and a bit of a "racy" look. Adding rear sway bars effectively raises the rear spring rates a bit more under cornering. All positive.
Old Apr 17, 2009 | 06:34 AM
heavychevy's Avatar
Originally Posted by D_Nyholm
I have PSS10's and am not happy with them. They have way too much bounce on whatever setting they are at. I've raised the car, stiffened them, made them softer, etc... and the front still bounces all over the place. How can i find out if it is normal or not? Is there any place that services them besides bilstein?
Causes of bumpiness in the front can be a few things, RWD can do it because of the loss of ballast in the front, and springs that are too soft for the dampers making you run the damping too stiff. This means your dampers are supporting the car, not the springs and obviously if you can't adjust the rebound the spring compresses and then bounces back really fast causing the bumpiness. This is a common problem with street suspensions because they come with springs that are too soft for the weight of our cars.
Old Apr 17, 2009 | 10:30 AM
unvmy996's Avatar
heavy what do you think about JRZ ?
Old Apr 17, 2009 | 01:00 PM
evo911's Avatar
evo911 is a jewel in the roughevo911 is a jewel in the roughevo911 is a jewel in the roughevo911 is a jewel in the rough
from what i heard over at switzers they used both and the KW is the way to go, i have the V3 on my BMW. Although on my pcar i love my JIC setup
Old Apr 17, 2009 | 02:34 PM
sshu930's Avatar
sshu930 is infamous around these parts
I have heard several stories of the PSS9's adjustment **** getting stuck and you are not able to adjust them anymore. I don't know if they corrected this issue with the PSS10's.
doughsun
Jan 31, 2016 04:22 PM
jaehoppa
Oct 22, 2015 09:17 PM
Taxthe1%
Sep 10, 2015 09:33 AM
ship it
Sep 7, 2015 10:49 AM
igdawgi
Sep 4, 2015 07:05 PM
