Filled up on 101 Octane today for the first time!
Finally found a gas station here in Chandler Arizona which dished out 101 Octane racing fuel (or so they called it).
It ran $3.99 per gallon and in the first 40 or so miles, I noticed the following:
Boost which was running at .7 almost all summer (in the heat here in the greater Phoenix area) hit a solid .8 and touched .9!
Not sure if it is worth the added expense of twice the fuel costs... but boy was it nice to see the boost gauge off of .7 bar.
Anyone else see such a drastic (in my mind) difference when going from 91 Octane to 101 Octane?
Joe West
Joe West
I always run a 50/50 blend of 91 and 101.
FWIW, there's a gas station on Chandler Blvd, West of the 10 about 2 miles, right next to an autoparts store. Thought I'd mention that just in case it is NOT the one that you already know about. It always helps to have a few alternatives in case one place is sold out.
Originally posted by msindi
Will be finding out soon - got my GIAC today and am scheduled to dyno stock and the 93 on tuesday then the 100 program on wednesday
Originally posted by Chris Y.
Would a blend of 91 & 101 be better than straight 101 for daily driving? Someone mentioned that straight 101 doesn't burn as quickly and can bog down the car...Humm???
I run the blend (actually 100/91) because my main EVO/GIAC program is for 94 octane. The blend gets me 95.5 octane, giving me a slight margin for error, which, if nothing else, gives me piece of mind, with the heat around here.
Re: Filled up on 101 Octane today for the first time!
Joe -- sounds like you may have an inaccurate/optimistic boost sensor if you're seeing .9 bar consistently with a stock Turbo. It's my understanding that Porsche programmed the stock Turbo ECU to reach maximum boost of .75 bar -- typically down low at around 2500-2800 rpms and then it tapers off rather quickly to .6. That's why most people only see .6 at higher rpm's (when they glance down at the boost gauge at the end of their run) and the occasional .7 bar. Brief boost spikes showing more than .7 bar (usually as you let off the throttle) are possible, but the "best " gas in the world will not cause a car to produce more boost than is programmed into its ECU.
Just my 2 cents FWIW.
Re: Re: Filled up on 101 Octane today for the first time!
Re: Re: Re: Filled up on 101 Octane today for the first time!
In my original post I said it touched .9 I guess I should have been more accurate. I get a solid .8 (up from a solid .7) and a blip at .9 which almost instantly goes back to .8
The factory manuals I have spec boost at .8 for a standard turbo, they unfortunately do not spec standard deviation around the .8 so I have no idea whether a momentary .9 is abnormal or not.
Keep in mind that we are dealing with 100+ temperatures here in Phoenix, and I am absolutely positive that ambient temperature plays a roll in how much of a difference you will see in boost performance as a function of octane.
At WOT, peak boost is appearing before redline and actually rolls off as I approach redline. I didn't note the numbers... just the trend.
Joe
Joe
Originally posted by racer63
You can also get a flawed reading if you lift off the throttle abruptly. Is the .9 bar steady state as you keep the throttle nailed (and don't lift) until you shift at or near redline?
The only way I know of for the Turbo engine to "know" what octane is in the cylinder is through the knock sensors, and it's when the octane is too low. If the knock sensors detect pinging the timing is set farther from top dead center. If no knock is dectected, the engine sets the timing closer to top dead center, to the timing where 93 octane is optimized.
The higher the octane the more retarded the gas is. To get the power out of higher octane gas the spark has to be delayed, relative to lower octane gas, to allow for more compression of the charge.
Octane shouldn't have anything to do with boost.
Re: Re: Re: Re: Filled up on 101 Octane today for the first time!
Joe
Joe
I've attached a photo of the boost curve graph (#1) for a stock Turbo -- thought you might find it interesting. Take note of the max. boost at 2500 rpm and the roll off as rpm's increase to a max. boost of barely more than .6 bar at redline. You can see that Porsche left a lot on the "boost table" with which after market chip tuners can play.
04-28-2022 12:38 AM
BlackMarketRacing
12-03-2015 10:46 AM
09-01-2015 03:16 PM
