Conditions under which PSM activates
Old Apr 24, 2009 | 10:52 AM
SAVED4IT's Avatar
SAVED4IT is infamous around these parts
Anyone care to share conditions under which Porsche Stability Management activates? I don't drive crazily, but I had an interesting situation pop up that made the PSM triangle light up and I could feel the brakes on a tire or two.
The situation was when I was going into a freeway interchange, which is a quarter circle over about half a mile. It's really not an aggressive turn at all. I've noticed in a high gear (like 6th) at low RPM (like, 2-2.5k) on this and other similar turns the PSM kicks on and slows down one of my tires. I never felt like I was out of control or in any danger of sliding. Hell, I wasn't doing anything differently than my Acura, which takes the turn at 65 no problem. Ironically, if I take the turn more aggressively in 5th at 75-80, it's never a problem!
Any thoughts? I'm curious to know under what conditions you've noticed PSM come on.
Old Apr 24, 2009 | 11:03 AM
s14roller's Avatar
s14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to behold
Maybe loose gravel/sand in that area
Old Apr 24, 2009 | 11:53 AM
996garage's Avatar
996garage is infamous around these parts996garage is infamous around these parts
I definitely experience that the PSM is overly intrusive on long freeway interchange sweepers. It will start braking and totally unsettle the car. Even after changing out the suspension with Techart coilovers and forged wheels, it's still the same. It only happens on the fwy interchanges for me.
Old Apr 25, 2009 | 03:11 PM
flash68's Avatar
flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !flash68 Is a GOD !
this is why I turn if off.
nlakind
Nov 6, 2015 10:15 AM
007AMV8
Oct 19, 2015 09:55 PM
henryr
Sep 24, 2015 08:22 PM
SharkyShark20
Sep 19, 2015 09:54 PM
spreeon
Aug 27, 2015 08:14 PM
