Rear tires rubbed through the fender liners
Old Apr 26, 2009 | 06:41 PM
landjet's Avatar
Jon, I have one of those in my tool kit.
Thanks for the offer of the spacers. I'll do some more research before I decide what to do. Need to find out the proper size from my tech. I'll get back in touch with you about it. Do you have the longer lug nuts to go with them?
Old Apr 26, 2009 | 06:42 PM
Al Norton's Avatar
Al Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud ofAl Norton has much to be proud of
Originally Posted by landjet
I can't understand why my car is doing this. I have stock tire sizes, 225/40/18 front, and 295/30/18 rear. My car is lowered 1 1/2 inches on PSS9s with a stock alignment on stock wheels. I would like to put 235s front and 315s in the rear but am afraid I will be rubbing through the IC hoses next. Any idea why this is happening? Any solution ideas?
Your solution is as follows: Loosen the 6 bolts on the driver-side compressor and "clock" the outlet with hose away from the tire. You can probably move the compressor outlet tube about 15 degrees and still use the OEM hose. The top bolt is hard to reach and you must take the second to top bolt completely out in order to reach the top one. This will all make more sense when you get under there and begin the procedure. (I just happened to think, the instructions I gave you apply to a Garrett GT30 series compressor. Yours is probably totally different). Get all bolts loose and give it a twist. Once you have done that, it can be a challenge to get the threads to re-engage on that second to top bolt. Patience is a virtue.
Don't worry about the inner fender liner. The safe thing to do is to see where it is starting to rub, then remove the liner and cut a relief in all directions. While you're in there, remove the flimsy steel liner bracket and bend it back a bit to help reposition the aft portion of the liner.
Old Apr 26, 2009 | 07:15 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
Yes, I'd send those too. If you want to do it, you gotta catch me this week, as I'll be away the entire month of May.
Old Apr 26, 2009 | 07:24 PM
LamboTT's Avatar
LamboTT has a spectacular aura aboutLamboTT has a spectacular aura about
I'm running 20x12 Iforged wheels in the rear with 315/25/20 tires. Lowered on H&R springs and my liners did rub a little bit but never put a hole through them as of yet. This might give you a little reference point. Fenders aren't rolled and this is about the max (some go 335 but maybe different tire brand) you can go without rolling the outside fenders or running a lot of camber.
Old Apr 27, 2009 | 09:32 AM
BigBadBen's Avatar
BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !BigBadBen Is a GOD !
My car is impersonating a GT2 It is a turbo with neg 1.4 camber and about a 25.5" ride height from the ground to the top of the wheel arch.
335 RA1's work fine except for the 1" hole in the fender liner. I have removed the support bracket and used a heat gun to reshape the liner per (Zippy) but it still rubbed through.
Old Apr 27, 2009 | 11:56 AM
landjet's Avatar
I'm going to try some spacers.
Old Apr 27, 2009 | 06:08 PM
LamboTT's Avatar
I'm at just about 26 in the rear and I forget the front but maybe 25.5 or so in the front from the ground to the middle of the fender arch.
Old Apr 27, 2009 | 06:30 PM
0396's Avatar
0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute
Ok,
Question for the experts...what if one has a GT2, how big can you go on stock settings? 315 max or 335's on the rears and how about the fronts?
Old Apr 27, 2009 | 06:59 PM
oak's Avatar
oak
something is way off. stock wheels shouldn't rub through with only 1 1/2" lowering if anything the lower you go the more clearence you should have at the hose. do you have adjustable upper arms? have you checked your toe? and eccentrics?
oufan2929
Nov 8, 2015 08:26 PM
L.A.P.
Oct 19, 2015 10:01 PM
horsepowerfarm
Sep 10, 2015 06:09 PM
L.A.P.
Aug 23, 2015 11:48 PM
Sterlingc1975
Aug 22, 2015 02:30 PM
