The Chronicles of Porsche Fault Code 94 - Tank Vent System (Major Leak)
Old May 4, 2009 | 07:30 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Well, after about a month of this code not wanting to go away on its own (I'd reset it and 5 days later it would be back), and my fuel sensor not working I got pissed and decided to tear into it.
Well, upon removing all of the fuel lines from the tank this is what I've found. My buddy swears that fixing this should cure my problem....opinoins?
Old May 4, 2009 | 07:39 PM
raineycd's Avatar
Is that a large crack in the plastic below the connectors?
Old May 4, 2009 | 07:55 PM
SIC996's Avatar
SIC996 is infamous around these parts
Hell, alittle Magic Putty and its all good! At least thats what the TV commercial says
Old May 4, 2009 | 08:02 PM
adam699's Avatar
Yes it was.
Here it is after a few minutes with a soldering stick
I'd do a better job but this is by far the smelliest, most toxic fume creating, making you cry plastic I ever melted.
I'll finish it off with some gas resistant silicone from the inside and outside, just to be safe.
I also measured up the fuel guage and the sensor checks out fine, I guess it just needs to be calibrated.
Old May 4, 2009 | 08:06 PM
raineycd's Avatar
You are too much! I really admire you willingness to tear these things apart and go at it!!!
Old May 4, 2009 | 08:19 PM
adam699's Avatar
Mighty Putty and Billy Mays has nothing on me
Old May 4, 2009 | 09:42 PM
BLKMGK's Avatar
I'd have gone for JB Weld. I repaired a cast exhaust manifold with that stuff once and it held for the two years the friend of mine still owned the car. :-O The repair you did looks good, hopefully it won't just crack again!
Old May 4, 2009 | 09:46 PM
CarreraMark's Avatar
CarreraMark is infamous around these parts
beyond the code, what problem was this causing? Thx
Old May 4, 2009 | 10:22 PM
adam699's Avatar
I wouldn't risk JB weld anywhere where there is gas/petroleum as it is an epoxy.
Old May 4, 2009 | 10:24 PM
adam699's Avatar
Annoying CEL light, and I'm not sure but my butt dyno tells me that it would limit the shifts on my TIP. Another thing is that with the CEL light on the MPG would drop to 14.7 and the car just felt like it was running pig rich.
Old May 4, 2009 | 10:38 PM
BLKMGK's Avatar
http://www.jbweld.net/faq.php#faq007
Old May 4, 2009 | 11:54 PM
adam699's Avatar
For wet-surface or submerged water or gasoline repairs, see our J-B Stik or Waterweld product information.
Since the gas tank is a closed system, I'm sure the fumes could soften the JB Weld.
I've tried it in many instances, from timing belt covers to engine blocks and muffler bearings and it didn't last long.
The weld I did using a hot "iron" by working the plastic is what most bumper repair shops use. It makes a bond as strong as "factory" as it restores the bond between the like plastic particles. The only reason why I used silicone is that if there is a pinhole creating the leak the silicone will seal it.
joseph_number1
Jul 19, 2018 05:45 PM
Jun 10, 2017 07:45 PM
