How to change the front lower control arm ?
Old May 20, 2009 | 01:46 PM
ThePunisher's Avatar
ThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud ofThePunisher has much to be proud of
Hi guys , i'm trying to change the front lower control arm with the GT3 adjustable one, but i'm having a big problem and i don't know how to solve it.
No problem to unscrew it from the cross member and no problem to unscrew it from the wishbone but after i have unscrewed the last bolt (the bolt that fix the control arm under the wheel hub) the screw of the control arm doesn't exit from the hub.
How can i solve this problem ... maybe a hummer (i tried but nothing to do) ... or maybe there's an easy way under my eyes but i can't see it !
I hope that my question is clear, i know that many words are not correct but they are too technical for my basic english !
Thank you
Old May 20, 2009 | 03:05 PM
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
I've attached below a couple of pages from the manual. You need a special tool to extract the ball joint from the hub as shown. Hope this helps.
Jon
PS - Your english was fine, except "martello = hammer" and "hummer = un pompino"
File Type: pdf
Old May 20, 2009 | 03:35 PM
Jon
Great, now i know that with a "hummer" probably i would get a very happy car and with a hammer a broken ball joint.
I need an extractor ... i hope to find something similar !
Thank you FastFwd ... great support !!!
Old May 20, 2009 | 09:27 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
These are a pita. Soak it with rust penetrator overnight. Than if you want to disregard the control arm, I recomment a few hits from an airhammerfrom the top or a good old $9 balljoint seperator from vato zone.
Old May 21, 2009 | 01:43 AM
FAST FWD's Avatar
[quote=ThePunisher;2393165]Great, now i know that with a "hummer" probably i would get a very happy car
/quote]
Or, at least a happy driver!!
Jon
Enemy
Nov 10, 2015 08:01 AM
COBB Tuning
Nov 9, 2015 08:02 PM
00aston
Aug 27, 2015 12:01 AM
TrackOne
Aug 20, 2015 12:56 PM
Aug 19, 2015 06:35 PM
