SportShift Gearbox
Old Aug 22, 2015 | 08:37 PM
00aston's Avatar
00aston is infamous around these parts
SportShift Gearbox
Changes are very clunky, making it quite uncomfortable to drive.
Would an box oil change assist on smoothening shifts? Note that I do go through the clutch learn process as stated in other threads.
Car has done about 40,000km and there is no mention by the previous owner of box oil changes
Old Aug 22, 2015 | 08:58 PM
Prefurbia's Avatar
Prefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond reputePrefurbia has a reputation beyond repute
Before you drive it next time, take 20 seconds idle before putting it in gear. Upshift manually lifting on the gas between shifts. See if that helps. I had an 07 6 speed, have now an 09 sportshift, and trading next week for a 15 GT and was considering a 6 speed but only because they are more common, then last minute changed to a sportshift. Once you drive it like its meant to, you will like it.
Old Aug 22, 2015 | 09:42 PM
00aston's Avatar
I do usually let it idle before taking off.
Do you think box oil would help?
Old Aug 23, 2015 | 02:31 AM
Prefurbia's Avatar
No expert on mechanical stuff, but others on this forum seem to be
Old Aug 23, 2015 | 03:42 AM
N91K's Avatar
N91K is infamous around these parts
The sport shift is a learning progress and thats why i love it. If its a new car to you then you'll need time to get used to it but if you've owned it for a while then maybe there's more to it.
Old Aug 23, 2015 | 06:35 PM
spinecho's Avatar
spinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to beholdspinecho is a splendid one to behold
Are you driving it like a manual? As stated above, you need to lift off the throttle on upshifts, and the timing and speed of the lift have to be varied depending on revs, how hard you are accelerating etc., just like in a manual, in order for the shift to be executed smoothly.
Old Aug 24, 2015 | 12:59 AM
rohnin's Avatar
rohnin is infamous around these parts
The problem is not at high speed driving, it's going through parking lots and such. The Sportshift is unpredictable when it decides to lurch or engage gradually
Old Aug 24, 2015 | 08:48 AM
spinecho's Avatar
Just don't drive it in 'D', ever, even in parking lots That way only you make the decision when and how to shift.
Old Aug 24, 2015 | 08:50 AM
rohnin's Avatar
Not true when you're backing out of a spot!
Old Aug 25, 2015 | 07:51 AM
Irish07@VelocityAP's Avatar
Welcome to the forums, but you might have some reading online and from that owners manual. The ASM for Vantage is NOT an automatic, just putting that out of the way..like a lot of others have stated, the Vantage ASM is a manual transmission vehicle, just shifted hydraulically.
What year and how much mileage.
Is it the original clutch.
Has the car been to the dealer for a fault scan, does it have the latest updates.
Do you perform a clutch learn every cold start, do you drive with D selected or paddles. Do you keep sport mode always selected.
Old Aug 25, 2015 | 09:25 AM
Prefurbia's Avatar
Ditto to above. Almost bought a '15 GT with 6 speed, decided to find one with sportshift. Had both vantages before... Prefer sportshift.
Old Aug 25, 2015 | 10:41 AM
spinecho's Avatar
Not sure what you mean. Reverse is an unusually tall gear, both on SS and manual Vantages, well known 'issue'. Maybe SS1/2 are different, but with my SS3 I have no problems with reversing - it just takes a very sensitive right foot to get the correct balance of amount and rate of throttle input for the desired result.
Old Aug 25, 2015 | 10:59 AM
rohnin's Avatar
Mine is a SS1, when you let off the brake sometimes it wants to lurch, other times it engages slowly (reverse). Yes I perform clutch learn at every start up
This will be a non issue as I'm selling the car this week
Old Aug 25, 2015 | 11:15 PM
00aston's Avatar
It's a 4.7L 2009
45000kms
Haven't seen records of clutch change- but it doesn't slip
Hasn't been to dealer yet- only had it for a short period. Serviced by Aston the week before I purchased it (evidenced by receipts)
Clutch learn every cold start
Driven mostly with paddles
Always in sport mode
Problem is mostly at low speeds - clunky shifts and the occasional stall.
I thought fresh box fluids will smoothen it up a bit. What are your thoughts?
Old Aug 26, 2015 | 12:20 AM
Prefurbia's Avatar
I had no problems like that with mine which was also a 2009, with 43,000 miles on it. I think it's worth taking it to the Aston Martin dealer who has the equipment to determine what the problem is cause it's not normal.
