tire question for 19's
Old May 22, 2009 | 09:44 PM
FlyYellow's Avatar
FlyYellow is infamous around these partsFlyYellow is infamous around these parts
Hi,
I'm looking for new rears for my car and i'm considering switching off the Michellin PS2 (too expensive).
what are my alternatives?
I dd see the Falken FK-452 and the Toyo-T1R, both are roughly equivalent pricing. Curious to know what others recommend...
Thanks...
Old May 22, 2009 | 10:10 PM
SXN's Avatar
SXN
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
I would go with the T1R's over the falkens anyday.
I'm using these cuz ps2's costs so much in 315's
Old May 23, 2009 | 01:11 AM
FlyYellow's Avatar
thanks - that's what i suspected to be the case. not much selection in this size (for some reason).
I must say i do wish there was the exact diameter of 25.5 to match the fronts. the rears being 25.2 s just a hair short...
Old May 23, 2009 | 07:15 AM
boca996tt's Avatar
boca996tt is just really niceboca996tt is just really niceboca996tt is just really niceboca996tt is just really nice
check out tire rack.com they have all listed sizes and reviews
Old May 23, 2009 | 10:47 AM
torch frc's Avatar
torch frc is infamous around these parts
I purchased some 305/30/19 Hankooks to replace my PS2s and I am dissapointed with the lack of grip
Old May 23, 2009 | 12:19 PM
SXN's Avatar
SXN
What did you expect man? I wouldn't even compare hankooks to ps2's
Old May 24, 2009 | 12:00 AM
r34dy2walk's Avatar
r34dy2walk is infamous around these parts
whats the reason for this?
i'm just curious because i was actually in the market for some new tires as well. i was debating over the FK452 or the T1R's
Old May 24, 2009 | 12:30 AM
SXN's Avatar
SXN
I've had fk452's and they don't compare to the T1R's I have now.
Old May 24, 2009 | 01:21 AM
r34dy2walk's Avatar
okay. they're basically in the same price range so I've just been trying to find out which to go with.
Old May 24, 2009 | 09:09 AM
boca996tt's Avatar
I hear nitto are pretty good
Old May 24, 2009 | 09:13 AM
ttboost's Avatar
I just bought some Sumitomos from TireRack in 18's. They have 19's but only go to 275's. Call Damon @ TireRack?
Old May 24, 2009 | 11:57 PM
shaunt's Avatar
shaunt has much to be proud ofshaunt has much to be proud ofshaunt has much to be proud ofshaunt has much to be proud ofshaunt has much to be proud ofshaunt has much to be proud ofshaunt has much to be proud ofshaunt has much to be proud of
I think you should look into Continentals as well. They are a little more the the toyos but quite a few hundred less than the PS2s
Old May 25, 2009 | 08:16 AM
WOODTSTER's Avatar
I actually liked the Conti's as well, but have had great all around success with the
PS2. I run 19" (235/35 and 315/25), and like them as they are predictable good all around tires. Funny thing about PS2's is that on ATOMIC Z's Z06, he didnt like them
in the size he was running (I cannot remember size but the actual sidewall height of the PS2 was much taller than my 315/25) as the sidewall is kind of spongy, and he
felt the Z06 squirmed in the rear at high speeds. I have not had that problem.
Let us know if any of these lesser priced options come in a 315/25/19 and what the
price differential is. The PS2's just seem to work very well in all conditons.
MK
Old May 25, 2009 | 09:00 AM
PrecisionPorsch's Avatar
PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !PrecisionPorsch Is a GOD !
Boris,
I would stay away from Falken only b/c they run small to their size. I have seen a set of 275/35 Falken 452's and T1Rs (same size tire) on a 10" wide rear wheel side by side and the 452's gave it a real stretched look and left the lips exposed while the T1R filled up the 10" wheel well. I wouldn't buy falkens unless I was going for a VIP, flushed/fender look with an exposed lip. Alot of the VW/JDM guys like to run falkens b/c of that feature. Just my 0.02. I will be running 315/25's T1R's on my 12" rear.
Edwin
Old May 25, 2009 | 09:20 AM
boca996tt's Avatar
check out the nitto INVO I heard good things about them
