How often do you replace your tires?
Old Jun 12, 2009 | 10:28 AM
Chuck Jones's Avatar
Chuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond reputeChuck Jones has a reputation beyond repute
Damn....I tried to address the lack of data and got nailed on semantics. So, did you take a major in statistical analysis and a minior in english?
Insofar as Porsche quality goes, given the warranty work....you should have what essentially amounts to a new car sitting in the garage.
447: It sounds more like your extended high speed driving is heating up the tires and eventually causing the centers to wear a bit faster than the edges. You might try dropping the 44 psi rear pressure down a bit to even out the wear across the face of the tire. Some guys will put a wide chalk mark across the tire and run it to see which portion of the tire isn't making contact with the roadway....then adjust pressure accordingly. I keep an eye on the groove portion of the treads (Michelin has a three groove pattern) and use that to gauge the pressure levels. I'm sure you've had them aligned too. Also...you usually see the right rear tire wearing faster than the left rear.
Old Jun 12, 2009 | 12:45 PM
pvanosta's Avatar
pvanosta is just really nicepvanosta is just really nicepvanosta is just really nicepvanosta is just really nicepvanosta is just really nice
I get between 3500 and 5000 out of my rears. Fronts last 3 times that.
Old Jun 12, 2009 | 07:51 PM
RCNJ's Avatar
RCNJ is infamous around these parts
900hp GT2= 3200 miles on rear NT01's...passed the wear bar
Old Jun 12, 2009 | 07:55 PM
jcb-memphis's Avatar
jcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond reputejcb-memphis has a reputation beyond repute
sum htr Z III's at 8,000 front and rear now, no real wear up front (really, <2mm), rears are half done.
My prior contis were 10k in the rear.... I think the sumi's will be 15 to 17k in the rear! No DE on them....fyi.
Upon putting on my suspension, I had things optimized not just for handling, but to be nicer than evil to the tires.....I gave up that last 1% of grip to get 2x tire life I think.
Jeff
Old Jun 12, 2009 | 08:49 PM
landjet's Avatar
Of what suspension mods do you speak?
Old Jun 13, 2009 | 09:46 AM
SXN's Avatar
SXN
SXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to beholdSXN is a splendid one to behold
My rears usually last 2 seasons at the most.
Fronts last double that.
audipwr1
Sep 25, 2021 01:31 PM
L.A.P.
Oct 19, 2015 10:01 PM
The Oss
Aug 24, 2015 08:19 PM
Zero911
Aug 24, 2015 06:51 PM
L.A.P.
Aug 23, 2015 11:48 PM
You have already rated this thread Rating: Thread Rating: 3 votes, 5.00 average.
