Upgrade Stock Speakers
Old Oct 26, 2004 | 03:04 AM
ColorChange's Avatar
ColorChange is infamous around these parts
Please help guys. I am trying to replace the stock speakers. I am willing to replace the amp but don't want things to get too big or heavy. Ideally, I will just replace the speakers, no wiring changes or anything else; pull out and bolt in. Can you do this with the Bose system (with Most)? If you go after the amp, will it interface directly with the head unit? What speakers fit well and can matched with an easy replacement amp?
Thanks,
Tim
PS: I have a nice home theatre and am running a Fabspeed Loud so I really don't need a nice system in the Pcar. I just want better the the truly POS Bose.
Old Oct 26, 2004 | 03:14 AM
Gary (Fl)'s Avatar
The Newest "Bling King"
Gary (Fl) is infamous around these parts
I asked the same question a long time ago and was told that the issues is the AMP.... So changing the speakers out will do you no good...
I was looking for just a little better sound myself...
Old Oct 26, 2004 | 09:07 AM
dlm477's Avatar
dlm477 is infamous around these parts
Ya, I have all the stock speakers but two heavy amps in the front ,and 3 subs in the back. Lots of weight but sounds incredible even with stock speakers. If you don't want all that weight, upgrade the head unit and make sure it comes with a powerful amp, not as powerful but saves the weight of a heavy amp. A nice head unit with amp should run around $600. If you are looking for good sound quality, the speakers should be upgraded to. I am sure your local shop can help u out. Dan
Old Oct 26, 2004 | 07:17 PM
dlm: The stock speakers sound OK wiht a new amp? I am shocked. I know the subs are the weakest points on the Bose but I really thoufht the stock speakers were fairly lame.
I don't want to upgrade the head unit. I just want better sound and will do the speakers and an amp in necessary, and no more. Is this possible?
Old Dec 16, 2004 | 09:56 AM
turbosteve's Avatar
turbosteve is infamous around these parts
Stock Speakers
Hello, I am trying to get the part numbers for changing out my stock speakers as they are blown.
I have heard that MB Quart make a good "bolt in" replacement. Does anyone have experience with these and if so do you have the part numbers? I would change out the dash, door and rears.
If not MB Quart - any other good suggestions?
I have heard that the Boston Accoustics are a good fit - anyone done these?
The car has the DSP so I think it has enough power to drive them.
2001TT - Thank you
Old Dec 16, 2004 | 11:02 AM
Mr Kram's Avatar
Mr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond reputeMr Kram has a reputation beyond repute
The stock speakers are OK if you push good clean power through them. Upgraded subs make a big difference also.
Old Dec 16, 2004 | 01:14 PM
Garey Cooper's Avatar
Garey Cooper is infamous around these parts
What is a good head unit that would fit into the stock opening, with the correct features?
00aston
Sep 16, 2022 09:19 AM
Superaudiofreak
Jun 10, 2016 02:04 PM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
vr6tee
Aug 29, 2015 03:52 AM
