Intercooler information ???
Old Jun 22, 2009 | 05:52 AM
Prche951's Avatar
Originally Posted by Red 9
The intercoolers will not get you a gain in HP--more accurate to say better intercooling will let you keep the HP you already have.That may represent 100HP if it is hot enough.It is after everything gets hot that the intercoolers start to do there job.
A couple of more recent threads that have some good comments on named brands --here on 6 Spd---KPG comments on Evo vs B-6 --that has some real back to back that is really interesting. On Rennlist--997 TT thread( near enough identical i/c's and issues) TB's thread contains AWE details and some REAL testing --plus another thread on custom cores made up and the results( still very current) .
yes, some people look at it as a gain. some don't. I agree with you. It's the same with using 91 octane on a pump gas file for 91. On hot days or with worse fuel than normal the ecu pulls timing and you loose power. Using a 93-95 mix doesn't gain you power, but it keeps the ecu from pulling timing so you retain the power you should have had. KPG's results were interesting, but they are for a monster motor build running huge numbers in an extremely hot place(hell). There would not be anywhere near that much difference in a lesser power motor in a slightly cooler place.
did not read awe's results.
ECS Tuning - VW
Sep 2, 2015 01:47 PM
ECS Tuning - VW
Sep 2, 2015 01:19 PM
ECS Tuning - VW
Sep 2, 2015 12:58 PM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
