Good Reference for Brake Pad Change
Old Oct 27, 2004 | 02:25 AM
StephenTi's Avatar
StephenTi is infamous around these parts
http://www.heumann.com/bigred/index.html
Old Oct 27, 2004 | 04:06 AM
JakeMate's Avatar
JakeMate is infamous around these parts
Nice. Thanks.
Old Oct 28, 2004 | 12:14 AM
james's Avatar
Carolina Speed
james is infamous around these parts
Nice article. Question: I read that you should replace the little codder pin that holds the steel bar each time you change the pads. I've never done that and wonder if others have and where you can get the pins
Old Oct 28, 2004 | 01:11 AM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
2 minor tips.....take cap off brake fluid fill and put a rag over that while you work.
When you are completely done pump your brakes (or you'll run into the back of your garage with your foot to the floor)
Personally I have the sensor wires tie'd back up behind the rotor and never connect them.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
00aston
Aug 27, 2015 12:01 AM
rnl
Aug 26, 2015 02:36 PM
MDYUKI1016
Aug 24, 2015 04:40 PM
