With new rims do you need....
Old Jun 24, 2009 | 01:45 PM
enoyskt's Avatar
enoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to beholdenoyskt is a splendid one to behold
New lugs? I remember some vehicles need (tuner lugs) when you purchase aftermarket rims because the stock lugs will not fit anymore. Is this the same case with the 996TT? Or will the stocks be ok?
Old Jun 24, 2009 | 01:48 PM
soothsayer's Avatar
soothsayer is infamous around these parts
If your new rims need spacers, then you need longer lugs to compensate for the size of the spacer.
Old Jun 24, 2009 | 02:05 PM
enoyskt's Avatar
No spacers scenario. How about the correct offset for 996TT. Can you still use the existing oem lug nuts? Or do you need (tuner lugs)
Old Jun 25, 2009 | 08:58 AM
AndreWB's Avatar
Site Sponsor
AndreWB is a splendid one to beholdAndreWB is a splendid one to beholdAndreWB is a splendid one to beholdAndreWB is a splendid one to beholdAndreWB is a splendid one to beholdAndreWB is a splendid one to beholdAndreWB is a splendid one to beholdAndreWB is a splendid one to behold
Really depends on the wheel manufacturer. Some wheels will use oem lugs and others will provide a set of new ones.
Old Jun 25, 2009 | 09:18 AM
Technological's Avatar
Technological has a spectacular aura aboutTechnological has a spectacular aura aboutTechnological has a spectacular aura about
Some aftermarket wheel use a different seat than OEM as well. Cone versus ball seat. VERY important to check and make sure you aren't using cone type lugs on a ball type wheel, and vice versa. That's how wheels fall off.
Old Jun 25, 2009 | 12:15 PM
GreggT's Avatar
GreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to beholdGreggT is a splendid one to behold
I agree.....it is best to avoid......wheels falling off.
What are tuner lugs?
Old Jun 25, 2009 | 12:25 PM
enoyskt's Avatar
Ah, good tips, I will make sure. Tuner lugs are aftermarket lug nuts used on vehciles that have aftermarket rims which do not accept oem lug nuts or whatever reason
Old Jun 25, 2009 | 12:33 PM
GreggT's Avatar
Nuts?
Pretty rare for Turbo wheels (aftermarket or otherwise) to use nuts unless we're talking bolt-on spacers.
s6spd
Oct 6, 2015 08:20 PM
Oscar 987
Sep 29, 2015 04:57 PM
manfred@loma_wheels
Audi
Sep 26, 2015 07:49 AM
manfred@loma_wheels
Sep 2, 2015 11:22 AM
