Turbine speed
Turbine speed
The latest issue of Christophorus says the original Turbo (1974) had a maximum turbine speed of 90,000 rpm.
Anybody know what the max rpm is for the 996 Turbo's turbine(s)?
Originally posted by james
I bet it's less than an F-15 . . .
The other big difference is you can't refeul air to air.
So the real question is how does boost pressure on the 996 Turbo relate to turbine speed on the K16 and K24 turbos.
Assume a stock car. Do some of the chips overspin the turbos?
Originally posted by Dock (Atlanta)
It wasn't uncommon to have flames shoot out +30' from the back AND the front of the engine. All of this was fixed when digital engine controls were retrofitted.
and are you a pilot? if so, very cool.
Originally posted by Ruiner
For some reason I can't help but think of this convo:
"You were in a 4g inverted dive with a Mig28?"
"Yes ma'am."
"At what range?"
"Um, about 2 metres."
"It was actually about 1 and a half I think. It was 1 and a half, I've got a great Polaroid of it, and he's right there, must be 1 and a half. "
"Was a nice picture."
"Yes ma'am."
"At what range?"
Originally posted by Ryan S.
you wouldnt happen to have any pics of this would you?
And yes, I flew F-15's.
A quick story about the engine stalls...
When the engine stall occured, the engine had to be shut down and restarted. Sometimes it didn't start following a stall and you'd just RTB and land single engine. I remember one day flying out in W-386 off the coast of Virginia...we were about 200 miles off shore and we were doing ACM (Air Combat Manurever) training above the weather. It was solid clouds from the water up to 30,000 feet, but clear above, so we were playing up high. One of the F-15's got pretty slow at high angle of attack (the worse place for having an engine stall) right at the top of the cloud deck when both engines simultaneously stalled throwing huge flames from the front and back of the engines. He dissapeared into the clouds almost immediately. Starting one stalled engine in visual conditions is one thing, doing it in the weather is a whole other attention getting task. But BOTH engines gone in the weather is about as tough as it gets.
proTUNING Freaks
Sep 15, 2015 07:28 AM
