DIY Head Light Switch Remove and Replace
Rating: Thread Rating: 2 votes, 5.00 average.
  #46
Old 10-09-2012, 03:55 PM
Benjamin Brochste's Avatar
Benjamin Brochste is on a distinguished road
Thank you for the post. Dealer wanted $380 to replace the switch. I used a #20 Torx driver $4 (needs to be thin to access the screw in the switch, and short to access the screw near the door hinge) and a paper clip to release the switch lock then used canned air to blow out the dust from the switch. Works fine now. THANKS A MILLION!!!
  #47
Old 10-09-2012, 04:32 PM
mjos's Avatar
mjos is on a distinguished road
Thanks for the write-up. I cleaned mine and all is good again!
  #48
Old 10-13-2012, 12:39 PM
Exclamation
FYI - canned air fix did not last long.
I removed the switch and sprayed with MAF cleaner, moving the switch through all the positions several times before the solution dried. It works now, we'll see for how long. I will report should the switch fail yet again. Confirm the 24mm socket was useful, kept me from scratching things up.
  #49
Old 10-13-2012, 04:59 PM
rlougee's Avatar
rlougee is on a distinguished road
MAF Cleaner works
I cleaned mine in Feb. Not one problem since.
  #50
Old 10-13-2012, 08:44 PM
JG GT500's Avatar
JG GT500 will become famous soon enough
Everyone using MAF cleaner? Contact points only?
Got everything out, going to pick up some MAF cleaner tomorrow.
  #51
Old 10-16-2012, 11:09 AM
JG GT500's Avatar
MAF Cleaner worked like a charm. Light switch fully operational now.
Note, you don't need to use screwdriver to pry off the plastic bezel. There is a notch in the bottom to access the locking mechanism - use a small screwdriver to unlock, then bezel should come right out.
  #52
Old 12-22-2012, 06:17 PM
gonz2828's Avatar
gonz2828 is on a distinguished road
Ok... my turn now and I'm glad I found this thread. I'll give a try to the MAF spray and report back on my results... thanks to all for all this great info.
  #53
Old 12-23-2012, 09:46 AM
ronole's Avatar
ronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud ofronole has much to be proud of
I did this recently. Excellent DIY write-up and thanks to the author for taking the time to do it. Unfortunately, cleaning didn't do the trick but the replacement switch did.
  #54
Old 01-21-2013, 02:59 PM
Dan Babb's Avatar
Dan Babb is on a distinguished road
To anyone who has replaced or cleaned their switch....when the switch would fail, did it throw the PSM/ABS codes? Did your brake lights stop working too?
Trying to see if the headlight switch is the root cause for a problem I'm having.
  #55
Old 01-21-2013, 06:13 PM
tscales's Avatar
tscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to beholdtscales is a splendid one to behold
As I recall, the answer for me was no and no. No code, just the headlights. From memory though.
  #56
Old 01-21-2013, 06:59 PM
rlougee's Avatar
Headlight switch
Dan,
For me, no it didn't affect the tail lights. Only the headlights coming on.
I don't know if it threw a code. I didn't get any indication. Would I get a dashboard indicator of the code if it did? If so it didn't throw a code.
Rick
  #57
Old 01-21-2013, 07:37 PM
2001Porsche911's Avatar
2001Porsche911 is on a distinguished road
Brake lights worked fine and no code when mine failed
  #58
Old 01-21-2013, 07:41 PM
smistry007's Avatar
smistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond reputesmistry007 has a reputation beyond repute
same for me- no brake light or cel or psm lights
  #59
Old 01-21-2013, 11:32 PM
code7rpd's Avatar
code7rpd has a spectacular aura aboutcode7rpd has a spectacular aura about
Same here, just the headlights were out.
  #60
Old 01-23-2013, 05:48 PM
Dan Babb's Avatar
Talked to the service dept today and he thinks it is the headlight switch.
Sitting in the car now and I cant get the cover of the switch to pull off...the part that rotates. Is there a trick or some type of release clip to pull off?
You have already rated this thread Rating: Thread Rating: 2 votes, 5.00 average.
Quick Reply: DIY Head Light Switch Remove and Replace
