Turn signal broken, will hold to left but won't hold to right.
Old Jul 12, 2009 | 05:09 PM
drhenrock's Avatar
drhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to beholddrhenrock is a splendid one to behold
Question Turn signal broken, will hold to left but won't hold to right.
When I turn left it aslo won't rset to off. I have to hold it on to turn right. I hope this isn't a stealership repair??
Old Jul 13, 2009 | 01:18 AM
Kato's Avatar
Kato is just really niceKato is just really niceKato is just really niceKato is just really niceKato is just really nice
My independent replaced that part on my car when I bought it a few years ago. Wasn't too spendy as it's not the entire wheel/cluster, etc... Dealership will charge you an arm and a leg typically...
Old Jul 13, 2009 | 08:09 AM
$manager's Avatar
$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !$manager Is a GOD !
Doesn't it act like that if a bulb is out?
Old Jul 13, 2009 | 06:15 PM
dog4delta's Avatar
dog4delta is infamous around these partsdog4delta is infamous around these parts
Same thing happened to mine a few months ago. The turn signal lock/ratchet mechanism broke internally. It would "lock" in one direction but not the other. Best price I found for a complete new 4-post stalk assembly was through Suncoast Porsche for just under $200. Unfortunately, you can't replace just the turn signal switch. At least not without some drilling and riveting of the stalk / switch assembly, and you can't simply buy the turn signal stalk by itself. There is a good DIY out there complete with good photos that shows how to remove and replace the steering wheel. Once you get the wheel off, the stalk switch assembly is not too difficult to replace. Remove a few screws and it's pretty much plug and play. Using the DIY for reference, I think it took be about a hour or so to swap it out. You do however need to have some modest skills, as you have to remove the airbag and wheel, and some of the plastic trim around the wheel can be a little tricky. For reference, my local dealer quoted me a rough estimate of $150 for labor to swap out the assembly (parts not included).
Old Feb 16, 2010 | 12:24 PM
drifter12's Avatar
drifter12 is infamous around these parts
dog4delta: do you happen to have the DIY handy so I could refer to it? that would be greatly halpful. thanks very much.
Old Feb 16, 2010 | 02:21 PM
Steve Theodore's Avatar
Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !Steve Theodore Is a GOD !
I have a PDF for instructions about how to remove the steering wheel that I can e-mail you if you need them. Feel free to PM me if you need them. Also, I just removed my steering wheel yesterday (following these instructions) and it's truly a piece of cake.
Old Jan 17, 2012 | 12:57 AM
jwspeed's Avatar
jwspeed is infamous around these parts
I can use those steering wheel removal instructions....may have info on steering column tab that resets turn signal switch.
cadman
Nov 13, 2025 08:57 AM
MAcarbon
Mar 6, 2017 08:16 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
MAcarbon
Aug 24, 2015 03:26 PM
MAcarbon
Aug 19, 2015 04:52 PM
