996TT turbo boost problem?
Old Jul 14, 2009 | 07:48 AM
PEF's Avatar
PEF
PEF is infamous around these parts
Hey guys!
Got a problem with my turbo boost on track.
Normal driving gives no problem and I still get the basic 0.9bar but on track after 10mins my turbo boost only goes to 0.5bar.
The weird thing is, it appears when I use my 2nd gear more often. If I stay in 3rd and go smoother on the flat she has no problems. Also tracking in the rain gives no turbo leak as well...
Is this a problem due of the waste-gate? Maybe it could be related with another mechanical problem? Or an ECU problem?
Because otherwise I don't have a clue and sometimes a little air problem can lead to failing valves...
Thanks for the help!
Old Jul 14, 2009 | 07:55 AM
WOODTSTER's Avatar
heat soak, limp mode
Old Jul 14, 2009 | 08:00 AM
PEF's Avatar
PEF
So it can be a tube that takes false air in due heat? And so she goes into save mode...
Old Jul 14, 2009 | 03:13 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
Any mods to the car? Did you check DV's? Possible WG rod.
Old Jul 14, 2009 | 03:32 PM
wross996TT's Avatar
Seems there have been quite a few boost issues lately. It is most likely a
1. hardware issue (leaks)
2. Software issue
3. environmental issue, or
4. fuel
or some interaction from the above list.
Old Jul 14, 2009 | 03:52 PM
PEF's Avatar
PEF
Nope it's a basic 996TT with 420bhp. The only mod I got is the europipe stage 2(loud). But it only gives more sound.
Problem like a leak/temp heat seems the most fair answer I think.
With software problem, I should have the problem in the rain and while driving slower.
A fuel problem could be but yet again, the problem changes when I use the car on track only.
Thanks for your answers guys! I'll let you know. 2 more trackdays (Spa and Le Mans bugatti) upcoming so I can test it. Than she goes in for maintenance. Not enough time before vacation they said
I'll closely look at my temp water/oil gauges and stuff!!! But in former cases everything stayed normal.
tropicatango
Jun 8, 2025 01:00 PM
BlackMarketRacing
Dec 8, 2015 01:49 PM
Yotam Refael
Cayenne
Aug 18, 2015 03:03 PM
