Fuel pump system exposed, a couple of pictures
No issues with the fuel heating? Sean's (SRM) billet hat and a 340lph pump is what I'd go with but the stock hanger could take one of those pumps too. The Walbro are thinner but if you put a decent sized worm clamp around them the tail sticks out whe tightened and holds it like a spring in the hanger. Mod the wiring and off you go. Size of pump depends on power. Not used to systems that run a consistent pressure, I'd think tuning that would be a pita.
i sent him a pm with sean's contact info. he has everything needed to run without a fpr and a brushless pump in the srm hanger. whether he wants to spend the cabbage to do it right one time or not is up to him. fwiw i run a walbro 465 in the stock basket for duty under 5 psi. once the motor is back ill swap to the sam brushless setup and ditch the fpr altogether
no regulator at all. use pulse width modulation and boost request thru the proefi. its a brushless high pressure pump he is using
Yes it controls the pump
believe it or not lol
I found a Fuelab Prodigy pump. DC brushless driven pump. "Digital fuel delivery, more durable, more efficient and lower current draw". 10AN inlet / outlet. $440 from speedway motors. Looks external to me though so would need to run a surge tank type setup, etc. Just FYI.
This little gem flows in excess of 700lph, uses less power and drops right into our existing kit.
