oil level issue
Old Aug 23, 2009 | 02:33 AM
jrho's Avatar
jrho is infamous around these parts
oil level issue
well, have a '03 x50tt with recent mods, ecu,intake/exh,DVs,etc and noticed that the rpm is >1000 on park and i can't measure oil level unless i goto D or R and hold brake, to bring rpm down to about 800 or so, then the car thinks it's in idle mode and reads the oil level, WHICH is so full that all BARS are lit... i just had it changed at BBI ....is it ok to have oil that topped off?
james R
03 x50tip, agency power intake/exh/DV/Fhose, rss ipd plenum, softronics ecu,
Old Aug 23, 2009 | 10:07 PM
Liquidcooled's Avatar
Liquidcooled is just really niceLiquidcooled is just really niceLiquidcooled is just really niceLiquidcooled is just really nice
That's how mine is when I get it back from an oil change, all the bars are full. I won't worry about it BBI is a good shop they know what their doing.
Old Aug 24, 2009 | 02:01 AM
jrho's Avatar
oil level, burn rate
ok..that's good to know....
i plan on changing the oil every 5K with the m1 5-50 but wandering whether any of you actually have to fill/top off before a change....
i mean, how much does the typical 996 TT burn ? qt every 2500? i mean for normal daily driving, not tracking...
james R
Old Aug 24, 2009 | 06:50 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Have in mind that TT engines are twin turbo...so almost half of burned oil at 1000miles is burned in turbos...its not the engine responsible for all oil consumption...Oil level should be kept BETWEEN lower and upper point at all times...No more,no less than that...
Old Aug 24, 2009 | 09:20 AM
landjet's Avatar
I use about a quart between oil changes which is between 3000 and 5000 miles, but I track my car.
turkish1
Nov 11, 2015 09:01 PM
tkebp1275
Aug 31, 2015 06:35 PM
LiquidElephant
Aug 27, 2015 06:17 PM
gulf gt
Aug 27, 2015 10:27 AM
Zero911
Aug 24, 2015 06:51 PM
