Durametric drained my battery ??
Old Aug 26, 2009 | 10:08 PM
RCH's Avatar
RCH
RCH is just really niceRCH is just really niceRCH is just really niceRCH is just really niceRCH is just really nice
I hooked up the laptop yesterday (running from its battery) with Durametric and after 12 minutes my otherwise fine car battery was completedly drained ? is this normal !
Old Aug 27, 2009 | 03:27 PM
Softronic's Avatar
Veteran: Marine Corps
Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !Softronic Is a GOD !
Hello,
The Durametric tool uses a very low voltage is only from the LED activation. I would assume the car was not running and perhaps you had several of the users on? AC blower, radio etc. This with a week battery could cause it to lower to a point that it would not start.
You may want to fully charge your battery and check the cells for their specific gravity and perform a load test on it.
Best Regards,
Scott Slauson
Old Aug 27, 2009 | 03:30 PM
viprklr's Avatar
viprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond reputeviprklr has a reputation beyond repute
I had the durametric software hooked up with the laptop running over an hour 2 nights ago with no adverse result. Sounds like a bad cell in the battery.
Old Aug 27, 2009 | 04:17 PM
ant_8u's Avatar
ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !ant_8u Is a GOD !
iirc I think there is a message when you open the software which tells you to connect the car battery to a suitable battery charger when running the durametric
Old Aug 27, 2009 | 04:20 PM
jpflip's Avatar
I used Durametric often on my car (static) for long period using "drive links" for fans, vario cams etc and never had any battery problems....
Old Aug 27, 2009 | 07:34 PM
ABCar's Avatar
ABCar is infamous around these parts
Use the battery charger method or check your battery. How is your program?
adnanm3
Oct 25, 2016 08:38 AM
airbusdrvr
Dec 27, 2015 07:43 PM
Frank ( Sunnyside )
Bentley
Oct 3, 2015 11:13 PM
G ///Mcgregor K
Sep 30, 2015 01:46 PM
ECS Tuning - VW
Sep 30, 2015 12:21 PM
