Question regarding to JRZ
Rating: Thread Rating: 4 votes, 5.00 average.
Old Nov 13, 2004 | 06:17 AM
luting_chen's Avatar
luting_chen is infamous around these parts
what's the difference between double and triple adjustable???
^____^ thanx for the feedback...
Trying to figure out the differences... and the advantage and etc...
Old Nov 13, 2004 | 06:30 AM
Josh/AWE's Avatar
Double adjustability is being able to change compression and rebound.
The 3 and 4 way adjustable shocks allow you to adjust high speed and low speed compression or rebound.
Make sense?
Old Nov 13, 2004 | 06:53 AM
got it thanx ^_^
Old Nov 13, 2004 | 07:26 AM
JamE55's Avatar
JamE55 is infamous around these parts
Mike
Just curious. What would be the optimum setting (1,2,3 etc?) for street and track use? Or it just depends?
Old Nov 13, 2004 | 07:55 AM
sharkster's Avatar
Luting, just stay with double adjustable... Unless you track hard and on different courses a lot you won't get any real benefit. The more ***** you have to play with the more you have to know in terms of dialing it in Not easy
For example Carey brought up a very good point. When using remote resevoirs make sure you're on a lift to adjust them. All four wheels need to be off of the ground.
Old Nov 14, 2004 | 04:09 AM
Cary Eisenlohr's Avatar
Cary Eisenlohr is just really niceCary Eisenlohr is just really niceCary Eisenlohr is just really niceCary Eisenlohr is just really nice
Alex ... Sorry abou that, I think I may have confused you on that. The car only needs to be off the ground and fully extended when setting the pressures. You can adjust the compression and rebound ***** (with or without canisters) when the car is on the ground.
Old Nov 14, 2004 | 04:16 AM
Originally posted by JamE55
Mike
Mike, it sorta depends but a safe place to always start with the JRZ's is about 5 to 6 clicks counter clockwise from zero on the shock side (rebound) and 3 to 4 clicks counter clockwise from zero on the canisters (compression)
Try to never go below 80 PSI, usually stay in the 150 to 175 PSI range but in some cases you can go as high as 250 to 275 PSI .... like you said it all depends
PV=nRT.
Sep 9, 2022 06:06 PM
takenotes996tt
Jan 20, 2016 06:34 AM
HotRod
Sep 10, 2015 07:17 PM
pjb84
Sep 2, 2015 12:57 AM
You have already rated this thread Rating: Thread Rating: 4 votes, 5.00 average.
