Front end noise
Old Sep 5, 2009 | 03:27 PM
rh888888's Avatar
rh888888 is infamous around these partsrh888888 is infamous around these parts
Front end noise
I have an 02' 996 X50 The front end is making a clunking in the suspention. It makes the noise on a bumpy road and at a slow roll when you apply the brakes not under acceleration. The sway bar links are tight and every thing seams to be normal the passanger side strut mount ia a little sloppy but not bad. Problem is the noise is coming from the drivers side and that side seams tight. I am going to replace the strut mounts since the car has 400,000 miles on it (joking it has 45,000) Question is anthing else to look for?
Old Sep 6, 2009 | 07:37 PM
rh888888's Avatar
Any Ideas what this could be?
Old Sep 6, 2009 | 07:58 PM
Mad Ness's Avatar
Mad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant futureMad Ness has a brilliant future
might be the front upper strut mounts. Im looking at a car and the dealer maintenance records show this as a recommended fix. the notes read that the owner had complained of a noise.
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
Enemy
Nov 10, 2015 08:01 AM
New991S
Aug 31, 2015 05:22 PM
BLOWN SRT
Aug 25, 2015 01:28 AM
