GT700 shutting off
Old Oct 5, 2009 | 10:30 PM
GTstreet996's Avatar
GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !GTstreet996 Is a GOD !
Originally Posted by 2LOW4
Wow, I was hoping it was the fuel pump. Been following your Renntech thread over there on this as my 2001 is doing the same thing. I got to pull the codes with the Durametric right after it died in the driveway the last time without turning the key off. Got faults on the imobilizer. Thinking back on every time it happened, it was always a day after I washed it. I also have an aftermarket stereo. I'm doing the complete wiring check next.
Mine has LWFW, but as OP's case, engine dies under load, lifting on the the throttle, just sitting in driveway idling, just about any time. Hasn't happenede in about 3 weeks.
Sorry to hear. Hope you find something in the wiring check! This issue has to be the worst, the not knowing!!
Old Oct 5, 2009 | 10:37 PM
ScottKelly911's Avatar
ScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond reputeScottKelly911 has a reputation beyond repute
Originally Posted by flash68
Shuts off doing 80? Man that is jacked up!
and dangerous! I'd bring it to EVOMS and have them sort it out. it's about a 5 1/2 hour trip, but should be worth it, fly back, leave the car with them. Then fly back, pick her up and enjoy the ride back.
Old Oct 6, 2009 | 12:51 AM
melsta's Avatar
melsta has a spectacular aura aboutmelsta has a spectacular aura aboutmelsta has a spectacular aura about
i have the stage 2 clutch with LWFW and gt2 slave conversion kit and it does that occasionally when i come to a stop at the light.
Old Oct 6, 2009 | 01:58 AM
yllwturbo's Avatar
yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !yllwturbo Is a GOD !
Originally Posted by Prche951
you realize that it should not, right? was your car tuned with the lwfw or installed after tuning?
my car was tuned after the LWF was installed.
Old Oct 6, 2009 | 02:46 AM
ReeknHavic's Avatar
ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !ReeknHavic Is a GOD !
That happened to me a few times. It was the very first time I took my car for a spin with my new Proto tuned K24/18g. I spoke to Todd K about the stalling and he said the program should adapt. Sure enough it only lasted a day or two then it never happened again. It seems that Todd asked me if I was going to run a LWFW. So maybe he tunes for it? I don't know. Hopefully, this helps but my problem was only for a very short time and then it was an intermittent one at that.
Old Oct 6, 2009 | 04:06 AM
Prche951's Avatar
I am sure he modifies parameters at idle for the lwfw. there are 5 lwfw cars in my town and none of them have this problem, all of them are UMW setups, but it should not matter.
Old Oct 6, 2009 | 05:34 AM
Neil A's Avatar
Neil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud ofNeil A has much to be proud of
Just an idea but could it be the fuel pump relay over heating , i have known this to happen on other cars when the pump is running hard on tuned cars.
Old Oct 6, 2009 | 10:59 AM
Brand new fuel pump relay as well. I'm going to try new fuel filter today.
Old Oct 6, 2009 | 01:42 PM
wross996TT's Avatar
another thought...is it possible you are not getting enough fuel to the system...i.e., starving the system? I had this happen several times on my race tune (100+octane)...car just shut down and got christmas tree...
Old Oct 6, 2009 | 02:54 PM
I really think that is the cause but what did u do to fix the issue? since exact same thing is happening to mine.
Old Oct 6, 2009 | 03:36 PM
wross996TT's Avatar
I went back to pump ECU flash. If I am to use the race file I will have to upgrade injectors and rails...
Old Oct 6, 2009 | 03:41 PM
Ok that makes sense but I have the gt700 injectors and rails. Even when I use pump it shuts off.
Old Oct 6, 2009 | 04:36 PM
yllwturbo's Avatar
now i remember, my car did shut off when i came to a complete stop after hard driving. it wouldnt start , i checked everything but could find anything wrong.10-15 mins later it started right up like nothing ever happen. this was after it came back from Evoms for the 700 kit.
call me maybe i can help. too long to post if it work maybe u can post it up. it worked for me for sure 818 517-0307
pwdrhound
Sep 13, 2016 10:44 AM
BLKMGK
May 31, 2016 04:32 AM
pwdrhound
11
Nov 25, 2015 01:18 AM
