Could my chirp be a loose plug??
Old Oct 9, 2009 | 05:35 PM
steve harris's Avatar
steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !steve harris Is a GOD !
the car is on the rack gas off, the chirp seems to be coming from the middle of the head,only when the piston is firing underpresure it has to be an air leak,if it was a head gasket seems like i would be loosing coolant, and that we could see some leakage marks , nothing ,could i have a loose plug that looses air as the piston reaches its top cycle forcing air out?
Old Oct 9, 2009 | 05:55 PM
landjet's Avatar
If that were the case, wouldn't you hear it everytime the plug fired? Or see it with a smoke test.
Old Oct 9, 2009 | 06:04 PM
hear it every time we get to that cyclinder but no smoke escape anywhere, the chirp comes from that area and is caused by air, can't see the plug from the underside, but the chirp is way louder from under the car the chirp is only 5th or 6th turn with fuel off so motor will not start
Old Oct 9, 2009 | 07:12 PM
yep it was the plug pulled it little black tracings where the leak was what a relief!!! big thanks to ben at salerno motor sports in rocklin, for sTaying late and pulling the plug. came up the plug idea about 4:30 and the car is home and safe at 6;06 AT LEAST 15 MIN TRAVEL TIME ON A FRI NITE THANKS AGAIN BEN
Boltons991qtr
Sep 20, 2015 06:57 PM
jungt
Sep 16, 2015 05:28 AM
dan_189
Sep 14, 2015 01:03 AM
ECS Tuning - BMW
Sep 11, 2015 09:02 AM
BauerR
Sep 8, 2015 04:44 PM
