Upgradeing my wastegate springs to 10lbs..
Old Nov 27, 2004 | 01:43 PM
K24madness's Avatar
K24madness is infamous around these parts
Upgrading my wastegate springs to 10lbs..
Can someone help with the wastegate adjustment? I was told to adjust them to be closed at 11psi and start to move at 12 psi.
Any input would be appreciated.
FWIW I am doing this upgrade beacuse the wastegates are being blow open at boost levels over 1.1 bar. I want to run 1.2 -1.3 bar on my K24's.
Old Nov 27, 2004 | 02:43 PM
scotty slc's Avatar
scotty slc is infamous around these parts
1.0 bar is 14.7 lbs of boost. Depending on how your wastegates are set up you can have them set up to "creep" boost. Having a 1 bar spring, they should start to move at 0.9 bar, to keep the boost consistant. You could add more tention to the spring to hold the wastegate shut longer. Make sure your cars MAP sensor can sence the amount of boost, and that there is the proper amount of fuel, so you dont get any detnation.
What style of wastegate are you running? Are you running a boost controller?
-Scott
Old Nov 27, 2004 | 02:53 PM
K24madness's Avatar
The stock springs are 6-8 lbs. I am using a electonic greddy boost controller (profec A). I am upgrading the springs to 10 lbs. Since the spring rate is different than stock I assume stock adjustment proceedures do not apply
Old Nov 27, 2004 | 03:07 PM
scotty slc's Avatar
I would run the 10lb spring and bleed a bit more boost on top of the wastegate via the boost controller. I have never used a profec series controller, but I use a AVC-R. I have found that when you run a stiffer spring, boost controll becomes easier to keep consistant at higher boost levels.
I wish you luck!
-Scott
Old Nov 27, 2004 | 03:13 PM
scotty slc's Avatar
I wish you luck!
-Scott
Old Nov 27, 2004 | 04:03 PM
Blazin Civic's Avatar
Blazin Civic is infamous around these parts
Also keep in mind the AVC-R has great boost stability control. Also the new profec B spec 2s have this. Not to sure on the profec A though. AVC-R is the way to go for boost control but it is a pain in the *** to set up. RPM based boost control is great for traction though.
Jul 29, 2019 11:13 AM
The_Ruski_Driver
Oct 25, 2015 08:40 PM
inamjetdriver
Aug 31, 2015 08:01 PM
Just Cruise
Aug 25, 2015 10:45 AM
The Oss
Aug 24, 2015 08:19 PM
