Wider Rim Setup
Old Nov 29, 2004 | 11:39 PM
White GT2's Avatar
White GT2 is infamous around these parts
Wider Rim Setup
I am considering a wider setup on my GT2 in 18". Anyone here running 13" inch rears or know of a setup. If so, the model of rims and tire specs. Thanks.
Old Nov 30, 2004 | 06:42 AM
cjv's Avatar
cjv
Moderator
The widest wheels I was able to run withot extending the fenders were 12.5 inch Fiske FM10's rear and 10.0 inch front.
Old Nov 30, 2004 | 08:32 AM
White GT2's Avatar
What kind of tires are you running with that setup?
Old Nov 30, 2004 | 08:38 AM
Joe Weinstein's Avatar
Chad, you also had to do some structural moving stuff around
in the front to run those 10" wheels, didn't you?
Joe
Old Nov 30, 2004 | 09:56 AM
luting_chen's Avatar
luting_chen is infamous around these parts
chad:
how do u like the setup though? 10F and 12.5R
is it the exterior fender u're talking about or
u're talking about the modification of the inner wall?
Old Nov 30, 2004 | 08:40 PM
cjv's Avatar
cjv
Moderator
Two different types.
Michelin PSC's, 265/35-18's and 315/30-18's
Hoosier 275/35-18's and 335/30-18's
Old Nov 30, 2004 | 08:44 PM
cjv's Avatar
cjv
Moderator
Joe
The fronts required moving the radiator brackets slightly forward along with building a small aluminum box out where the plastic louvers were. About eight hours of work.
The rears required some small cut outs about two inches in diameter. These cut outs were replaced with hand formed aluminum. Very easy to do.
Pic of Hoosier 335/30-18's
Old Nov 30, 2004 | 08:48 PM
Turbo Fanatic's Avatar
I bet that Gt2 turns in like mad! I woudl also imagine it would be real tail happy? That's a LOT of grip up front for a 911.
Old Nov 30, 2004 | 08:54 PM
HotRodGuy's Avatar
that's a TT
Old Nov 30, 2004 | 08:57 PM
cjv's Avatar
cjv
Moderator
Some more with MPSC's.
Old Nov 30, 2004 | 09:06 PM
chad:
what's the widest setup u can get...w/o doing internal works?
what will u recommend? b/c i'm thinking about switching back to 18 soon...
Old Nov 30, 2004 | 09:24 PM
cjv's Avatar
cjv
Moderator
Originally posted by luting_chen
chad:
If you use the correct offsets, 235 and 315. To install the 315's I believe you will still need to roll the rear fenders.
Old Nov 30, 2004 | 09:43 PM
cjv's Avatar
cjv
Moderator
Originally posted by Soon2be993tt
that's a TT
turbo or GT2? Is that a compliment or insult? Just kidding.
Old Nov 30, 2004 | 09:59 PM
cjv's Avatar
cjv
Moderator
No, they are polished aluminum. Either dirty or bad pic.
Old Dec 1, 2004 | 01:22 AM
White GT2's Avatar
cjv, I do not want to roll my fenders on my GT2 what do you think my best option is with a strong 18" wheel? fiske or kinesis? do you think I can go with the 12.5" in the rear without a problem and what would be a comprable front? thank you.
