My car hates me!!!!
Old Nov 2, 2009 | 06:07 PM
007-911's Avatar
007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of
My car hates me!!!!
So driving home from work right now and I get a check engine light, it says, " check coolant level." I look back and white smoke is bellowing out the back of the car. I pull over and the car looks as if it is on fire. I didnt even punch it! It seems like the same stupid issue as before. I just had a whole new coolant system put in. I was supposed to have AMS and EPL tune the car tomorrow and now this happens! Anyone know why this is happenening? I just got the car back for the same issue and had it for like 3 weeks.
Old Nov 2, 2009 | 06:10 PM
s14roller's Avatar
s14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to beholds14roller is a splendid one to behold
Not sure why it happened but I hope it's a relatively easy fix!
Old Nov 2, 2009 | 06:17 PM
leftlane's Avatar
leftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond reputeleftlane has a reputation beyond repute
See if you can locate a hose that might have come loose - maybe a clamp failed and the smoke is coming from leaking coolant hitting something very hot. Is there an odor to it?
Old Nov 2, 2009 | 06:22 PM
007-911's Avatar
I tried to see if its just a loose hose but cant seem to find anything. I think it may be the same press fitting again. There is a sweet oder coming from it. Its hard to locate the hose as well because there is coolant everywhere.
Old Nov 2, 2009 | 06:37 PM
dtmarsh's Avatar
dtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud ofdtmarsh has much to be proud of
It's probably a good thing it happened now instead of after the tune.
Old Nov 2, 2009 | 06:44 PM
John@SpeedTech's Avatar
Did you previously have the oil cooler "pressed-in with epoxy" fitting pop out?
991.2 Turbo S GT Silver
991.2 GT3 Chalk (Manual)
2022 Cayenne White
www.speedtechexhausts.com
info@speedtechexhausts.com
Old Nov 2, 2009 | 07:13 PM
007-911's Avatar
no I did not have an oil cooler with epoxy
Old Nov 2, 2009 | 07:46 PM
ttboost's Avatar
Vince, is it wet behind 1 of the front tires? I had this problem and it was the vent hose popped off the radiator on the drivers side. They make an updated hose for this. Factory one has a metal end, newer one is plastic.
Here is the thread:
https://www.6speedonline.com/forums/...e-problem.html
Old Nov 2, 2009 | 07:51 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
could it be the coolant tank leaked on to the exhaust ?
could try pouring water in to see if it pours out any holes or hoses if u cant find the leak
Old Nov 2, 2009 | 07:54 PM
ttboost's Avatar
The coolant tanks on these cars are a maintenance issue. Maybe the tank just gave way...see if you can feel underneath the tank?
Old Nov 2, 2009 | 09:52 PM
VAGscum's Avatar
I don't think your car hates you. Just the coolant. That would explain why it is always trying to liberate itself from the car.
On a serious note. Was the smoke coming out of the exhaust pipe only or from under the hood? I would take the car to the people who put in the new coolant system. They possibly missed a clamp.
Old Nov 2, 2009 | 10:34 PM
Abdullah's Avatar
Abdullah is infamous around these parts
check if there is any leaking ,, thats means water pump , because i have same the problem before
Old Nov 3, 2009 | 09:19 AM
007-911's Avatar
Looked at the car and found the leak, it is a manifold that is behind the altinattor. It is a press fitting again!
Old Nov 3, 2009 | 09:27 AM
iJeremy's Avatar
iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !iJeremy Is a GOD !
How recently did you have the prior service done?... Sounds like they didn't correct it the first time so it shouldn't be anymore money out of your pocket to get it repaired, no?
Old Nov 3, 2009 | 04:20 PM
Mikelly's Avatar
Your car hates you???
Hate it back!
Mike
