Excited!! New Suspension Project on my 2003 GT2
Old Dec 7, 2009 | 07:17 PM
  #46
930man's Avatar
930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future930man has a brilliant future
Originally Posted by XPGT2
And you know from experience that the OSgiken is inferior to the Guards and Motorsports?????
I have run the OSgiken in 2 different cars, Honda S2000 SCCA T3 race car/996GT2 OLOA/UTCC, and couldn't be happier. I will also state that I have no experience with Guards/Motorsports LSD builds.
80shilling,
Sounds a lot like 930mans GT2 build, I would only comment that for track work 400/600 is going to be mushy. I run 600/800# springs and the ride is acceptable on the street.
Peter
800 600 works to... gt2 with power needs a lil softer rear end to put power down! what do i know though ...lol
Old Dec 7, 2009 | 07:19 PM
  #47
930man's Avatar
... i just drove it...
lil ole M3 went sub 2 the other day
Old Dec 7, 2009 | 07:22 PM
  #48
TT Gasman's Avatar
TT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant futureTT Gasman has a brilliant future
Thumbs up
Wow, hard core suspension Dude, I'm impressed!
Old Dec 7, 2009 | 07:40 PM
  #49
LUISGT3's Avatar
Great info in this thread.
Old Dec 7, 2009 | 07:51 PM
  #50
930man's Avatar
all i can say is my ole car was set up well ... wasnt it peter???
Old Dec 7, 2009 | 08:08 PM
  #51
80shilling's Avatar
80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !
Brilliant !!!! Thanks for the virtual Encyclopedia of information you just posted.
I am assuming that these settings are your track settings? Are you/have you used the Hoosier DOT R6's?
My Canister pressures are right where you recommend...
My front toe is slightly toed out, whereas yours is toed in.. What is the thinking behind the toe in in front? The toe-in in the rear is to help stability under braking, because the rears will spread under braking, therefore the toe in helps bring the wheels straight, compensating. I was led to believe that toeing the fronts OUT helped turn in and front end agility?
I will have the caster set to your specs, as mine is at 8.2 just now.
My sway bars are in the correct position that you recommend.
The rest, I will investigate and make sure what my corresponding settings are.
Once I have tracked my car, I will have a better idea of where I want to go on the spring rates.
Again, thanks for your efforts here, I'm sure it will help tremendously. As it stands, I am incredibly happy with the immense improvement I already feel vs. the stock setup. I have a few months of tweaking and driving ahead of me... That's half the fun of this stuff though..
Maybe one of the mods could make this a GT2 specific sticky, as I'm sure this is something that would help ALL GT2 owners to some degree or another.
Originally Posted by iLLM3
I will put this up here for everyone to see. All of this info was sent to me after opinions from Vic (VA122) on rennlist, Lex at Moton and Vic I believe spoke to Sofronas at GMG! It transformed my car..... Hope it helps!
"I'm still waiting for Lex at moton to call me back, he was racing.
Here goes
-center steering wheel first and lock in place (seriously no one does this for some reason.)
-Camber for DOT-Rs 2.6/2.4 f/r with shims or you'll lose your caster
-Caster 8.5
-toe 0/-2mm (toe in) per side f/r
-bar middle/1 from full soft f/r
-adjust rear dog bones for kinematic toe in (not out) if they don't know what i'm talking about leave go somewhere else.
-adjust rear toe links for 0 bump as above if they don't know what i'm talking about leave go somewhere else.
-springs 6in with 3 in helper (0-150 weight) visually it should be completely compressed when wheels are on the ground.
-600/800 or 600/900 up to 800/1000 more and you'll need slicks.
-rear locking plate for toe links help depending on what brand you have.
-re-corner balance the car with your weight in the drivers seat with sand bags. ( a LOT of shops forget the weight part)
-front bump kit is a must if you lower more then 20mm from stock
-rake/chassis height- 100/120 f/r or that ratio if you want to go lower, but too low you need the cup uprights
-canister pressure 150/175 f/r
you should be good to go from there and the rest is shock tuning. I'll get you the baseline from lex, depends on the springs you use (eibach)
"Wooo Hoo, Just talked to lex.
here we go,
yuo want a 4-5" min spring up front 600-700lbs with a 4" 150lb tender
In the rear you want a 5-6" main 800-900lbs and a 4" 150lb tender.
Canister pressure:
Front 150-psi
Rear 175 if you have the 22mm diameter shafts and 250 if you have the 14mm diameter. You have 22mm in front so you can compare to figure out which ones you have.
Shock settings.
F compression (on the shock body) 4-5 from 0
F Rebound (cans) 4 from 0
R Bump(compression) 4
R Rebound 5 from 0
From there you should be good to go, and let em know if you want to plug a pro in the car and sort her out once and for all. "
Old Dec 8, 2009 | 11:11 AM
  #52
iLLM3's Avatar
All I know is that when I had toe out, the car felt like it was taking off for liftoff over 100, the most scary/instability i've ever felt.. Brings a new meaning to front end nervousness and twitchyness... While it may have been better for the track (which it's suppose to be, since your wheels will be positioned for better turn in) I just never got comfortable with it and was wayyyy faster with that setup I sent you. Only things I adjusted were camber (2.8/2.6 F/R) and maybe one more click to the front swaybar towards full stiff.
I ran Toyo R888's and Hoosier R6's with this setup, the R6's with 3-4 heat cycles on them proved to be 6-8 seconds faster then my under 50% R888's, I guess not apples to apples but it was me slipping and sliding all around Monticello/VIR with my buddy stu filming me from behind, I had to eventually let him go. Slapped my R6's on? I was OUT on every single car that I tried to keep up with but had to let go, 2 997 GT2's with R6's, GT3's and was playing tango with a cool guy in a GT3 cup 996 variant.. This was at VIR, also clocked a 2:04 which was my fastest time there ever, and it wasn't a full clean lap!
Glad I can help you out, and for anyone who want's a nice solid setup to work with!
Martin
Old Dec 8, 2009 | 11:25 AM
  #53
80shilling's Avatar
The car is having the toe changed to your settings... going toe-in instead of toe out.
What have you done to allow you to reach more than -2 degrees of camber? Stock I can only get to -2.0 front and rear.. more than that, I guess I'll need camber plates?
Definitely looking forward to the next Laguna and Sears/Infineon track days.. I think this Car will really excel at Laguna.. the gearing should be near perfect and the surface is damn nice now..
I'll post updates as I tweak the car more. I will be changing ONE thing at a time from now on, keeping track of what every single change does to the car.
Thanks again.. One of the most useful and informative posts ever on a Forum in my opinion.
Martin
Old Dec 8, 2009 | 04:20 PM
  #54
iLLM3's Avatar
You can get camber plates OR just rotate the struts/add shims to gain more negative camber.. Thing is, the more negative camber you add without plates, I believe you sacrifice caster, soooo I would probably just go with the camber plates!
Very smart to keep logs of all changes, and not to do too many modifications or tweaks at the same time, you won't get accurate feedback!
Again glad I can help, let me know how of goes, it's the least I can do after wasting over 2 years of money/time and setups/different shops and components! I know how it goes unfortunately... Good luck 
Old Dec 11, 2009 | 12:20 PM
  #55
iLLM3's Avatar
So did you wind up making any changes? Did you compare it to your setup, how different was it??
Old Dec 11, 2009 | 12:52 PM
  #56
80shilling's Avatar
Thumbs up
Yes, I made a few changes...
Based on your settings, plus a bit of trial and error, we did the following:
Went to 600 lb front, 800lb rear Eibach Pro springs.
Dialed out the toe-out and went to your settings for toe-in.
I played with the settings for the rear, in terms of damping and settled on 5 clicks out from full hard for both low speed compression and rebound damping.. went with 8 clicks out from full hard on high speed compression.
At the front, getting the damping characteristics to match the rear took a few tries, but we went with 6 clicks out from full hard for compression, 5 clicks out from full hard on rebound and 8 clicks out from full hard on high speed compression.
After shimming and rotating, we got to -2.2 front and -2.4 rear negative camber.
I left the ride height as it was. Corner balanced again.
The Car is truly transformed. Of all the modifications I have made to all my Cars and Motorcycles over the years, I think that this JRZ setup with your settings for most of the geometry/camber/caster etc has been the most amazing... I got to drive the Car really hard down some local back roads that also have some long straights on them last night... FABULOUS!!! it now soaks up all the road imperfections on really terrible surfaces.. it stays planted, stable and I don't feel as if my kidneys are taking a beating any more..
It rained on my way out to Pt. Reyes (my destination last night), so I also got to see how the car was in the wet.. On PS2's the thing is great.. I pushed it pretty hard on a few safe corners and got the front and rear to slide (on purpose) and also got it to 4 wheel drift on a few as well.. Controllable, predictable, telegraphs what the tires/wheels are doing VERY well, easy to catch when it does get loose at either end.
On a couple of the longer straights, I had experienced the car leaving the ground when it hit a couple of specific bumps when it was on the stock suspension at 90 mph...SCARY STUFF... With this setup, I barely noticed that the bumps were there at 120+ mph.
Next step is the track.. Sears/Infineon is always a good test, because almost every car I have driven there exhibits understeer through turn 4.. If you dial out the understeer there, you get pretty scary oversteer in turn 10 (and that's one corner you DEFINITELY don't want oversteer on ).. Getting the balance right for turn 2, 4, the esses and turn 10 is the crucial part of setup. Laguna is different.. I always concentrate on getting the car neutral through turn 4 so I carry as much speed as possible through to turn 5 and get a good run all the way up through 6 and up the hill to the corkscrew... Turn 9 is also important, as you don't want oversteer through there. Turn 3? no-one thinks they ever quite get turn 3 right.. it's just a corner that you can push and push then suddenly you've crashed and you don't quite know why.. it looks flat, but it FEELS like it is negatively cambered..
So.. many, many thanks for going to the trouble to post your setup, it has helped immensely and now I feel real confidence in the car in all aspects of how it behaves and handles.
Old Dec 11, 2009 | 02:10 PM
  #57
80shilling's Avatar
Old Dec 11, 2009 | 03:08 PM
  #58
heavychevy's Avatar
Sweet Picture!!!
Old Dec 11, 2009 | 03:10 PM
  #59
landjet's Avatar
I have done my suspension just about the same way except I used Motons. Would you please describe the ride difference when you went to the 600/800 springs? My current springs are 450/700, and I always wonder if I should go stiffer. I drive mostly track now, not much street at all.
Old Dec 11, 2009 | 03:42 PM
  #60
heavychevy's Avatar
What kind of tires do you run?
If they are R-comps (R888, MPSC, NT-01) to Semi-Slick (R6, V710, A6) or stickier, then you will need a stiffer spring to control the pitch and yaw of such a heavy car. Between 500-700 front and 700-900 should be the workable range without any big wings on the car. Maybe even a little heavier depending on how aggressive you are and how smooth the tracks you attend are.
Running a stiffer sway bar allows a softer spring as well so keep that in mind.
Realistically, from the difference you have and what he has, you can use your compression range to make them feel pretty much the same. You are eliminating the bottom range of softness for the lighter spring, but you can make the mid range easily through softening the damper.
The weight of these cars + sticky tires makes a laughing stock of 400lb/700lb springs. Your dampers are doing ALL the work.
