Excited!! New Suspension Project on my 2003 GT2
Old Dec 11, 2009 | 06:28 PM
  #61
80shilling's Avatar
80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !80shilling Is a GOD !
Originally Posted by landjet
I have done my suspension just about the same way except I used Motons. Would you please describe the ride difference when you went to the 600/800 springs? My current springs are 450/700, and I always wonder if I should go stiffer. I drive mostly track now, not much street at all.
The difference seems to be that the car has less vertical motion.. I think that they support the weight of the car more and therefore maybe I'm getting less suspension travel. It remains to be seen if they will be better for track work overall, or maybe just for specific tracks.. I'm pretty sure I will go back to the 400lb Front, 600lb Rear setup for Sears/Infineon, unless testing proves otherwise. Laguna should be a 600/800 track, as should Thunderhill. Also, even though the swaybars are the same, I think the car has less give under side loads and cornering, but again, I'll only know for sure when I get out to the track.
I also think that the triple adjustables with the high speed compression adjustments are allowing the shocks to soak up the nasty surfaces and imperfections even though I have gone to a higher spring rate. More testing/driving on varied surfaces will tell me more this weekend (but it's raining all weekend here supposedly).
More updates to come after driving it some more.....
Old Dec 11, 2009 | 06:45 PM
  #62
sharkster's Avatar
Well done to Martin... He knows his stuff love this forum... And looks like you'll have some fun 80schilling
Old Dec 12, 2009 | 09:00 AM
  #63
0396's Avatar
0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute0396 has a reputation beyond repute
Fabulous write up- thanks to all that have contributed… Now if I only had the funds
80 shilling – congrats on your new ride / project!
Old Jun 29, 2010 | 12:03 AM
  #64
Red 9's Avatar
Red 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond reputeRed 9 has a reputation beyond repute
Any updates--more or less ! progress?
Old Jun 29, 2010 | 10:24 AM
  #65
80shilling's Avatar
The Car is as close to perfect as I think it can be...
With the JRZ/Protrac triple adjustables and the geometry changes, it's brilliant on the street and a monster on the track... With the high speed rebound circuits, I can dial out all the harshness, but can dial everything back tighter for the track.
As it stands, I have gone back to 400/600 springs
-2.5 camber F
-2.2 camber R
1/16th toe out in front, 1/16th toe in rear
25 1/8 ride height in front, 25 1/4 in rear
With these settings, it's phenomenal for weekend drives in the twisties and is turning 1:37's at Laguna Seca... For MY tastes, it's a perfect compromise. If I wanted to be more track oriented, I would go to -3.0 front -2.6 rear.
Cheers...
Old Jun 29, 2010 | 10:04 PM
  #66
Red 9's Avatar
Thanks --very interesting practical thread with good info from a number of people.Earlier you commented on track different settings -- any more thoughts on that now?
Old Jun 30, 2010 | 06:09 AM
  #67
Prche951's Avatar
was your time on street tires? if so, more power and hoosiers will definitely get you in the 1:20's. impressive for sure.
Old Jun 30, 2010 | 06:12 AM
  #68
heavychevy's Avatar
I'm pretty sure he was on hoosiers. And it will take more than just more power to get into the 1:20's at Laguna.
Old Jun 30, 2010 | 08:19 AM
  #69
Prche951's Avatar
no doubt.....
Old Jun 30, 2010 | 10:00 AM
  #70
80shilling's Avatar
Yeah.. that's on Hoosiers... To get into the 1:20's I would have to strip the Car out to get it to 2500 lbs and run slicks... 1:20's is pure race Car territory.
Old Jan 1, 2011 | 07:24 PM
  #71
SR20dat's Avatar
SR20dat is infamous around these parts
Coil overs
That should do the trick. Much improved
Old Mar 17, 2011 | 09:57 PM
  #72
K24madness's Avatar
K24madness is infamous around these parts
I will be removing a set of these from a GT2 with 2k miles on them. If interested in buying them e-mail me @ thogan7242@gmail.com
2lflat4
Nov 18, 2019 05:05 PM
Jul 29, 2019 11:13 AM
PelicanParts.com
GT3/GT2/GT Vendor Classifieds
Aug 18, 2015 03:42 PM
