Please help!
Old Nov 17, 2009 | 07:36 AM
  #46
vbmw335's Avatar
vbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant futurevbmw335 has a brilliant future
We ran yesterday night. Its still the same....we both were equal. I have a feeling with a race gas tune the results might be different.
Old Nov 18, 2009 | 01:44 AM
  #47
aroonkl's Avatar
aroonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rougharoonkl is a jewel in the rough
Thanks. Please keep us update. May be should set same boost/gas and see the result with your friend. (I believed that have read it somewhere your guys have same tuner, EPL.) A lot of members still curious about K24/18g & A28.
Old Feb 27, 2010 | 01:09 PM
  #48
jalmood's Avatar
jalmood has a spectacular aura aboutjalmood has a spectacular aura aboutjalmood has a spectacular aura about
i am suffering from the same problem, i allways get the following fault codes which trigger the check engine light:
1) p1128 fault code 360-oxygen sensing adaptation idle range bank 1 exceeds limit value.
2) p1130 fault code 361-oxygen sensing adaptation idle range bank 2 exceeds limit value.
i checked the sensors and they are fitted correct in their places, any ideas, i am getting fed up with this issue.
Old Feb 27, 2010 | 01:37 PM
  #49
FAST FWD's Avatar
FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !FAST FWD Is a GOD !
The manual pages for those fault codes are below. Could be MAF, vacuum leak, fuel pressure regulator.
Good luck.
Jon
File Type: pdf
Old Feb 27, 2010 | 08:08 PM
  #50
jalmood's Avatar
Good luck.
Jon
Thanks, i will start by looking there.
Old Feb 27, 2010 | 11:27 PM
  #51
jalmood's Avatar
could be because of the incorrect signal from MAF sensor, i've been getting the ABS/PSM off lights from third gears and higher when i go WOT everytime.
Any of you guys have this issue ABS/PSM off when going WOT on higher gears?
This only started when i installed the 1-Bar wastegate kit and started boosting to 1.3-1.4 Bars.
Old Feb 28, 2010 | 01:09 AM
  #52
aroonkl's Avatar
Do you have Durametric or scanner? Read value of LTFT (long term fuel trim + or - , and __% ) and post here. Many friends here could help you narrow objects to look for.
Old Feb 28, 2010 | 01:24 AM
  #53
FAST FWD's Avatar
Well, that's a pretty good clue. I suggest that you call EPL, since they did the tune for your car. They will probably ask you for a durametric data log as suggested by aroonkl. I suspect that it won't be too hard to diagnose once you have the data.
Old Feb 28, 2010 | 01:48 AM
  #54
jalmood's Avatar
yes i do have durametric, shall i log this data while driving the car or only idling?
Old Feb 28, 2010 | 01:57 AM
  #55
FAST FWD's Avatar
Seems to me that you are going to want the data when the car is throwing the CEL.
Old Feb 28, 2010 | 03:46 AM
  #56
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
Originally Posted by MARKSKI@911tuning
what the hell did they do at that shop????
My thoughts exactly....02's are not easy to screw up unless you cut and splice the harness.
Old Feb 28, 2010 | 06:59 AM
  #57
jalmood's Avatar
also, one thing i forgot to mention is that the car stalls and the engine switches off whenever i come to a full stop when pressing in the clutch, happens more often especially when i delete the fault codes from the ECU.
I have replaced the spark plugs and ignition coils 2 days back, this issue is not releated since the engine switching off been happening for a long time now whenever i erase the fault codes.
Old Feb 28, 2010 | 07:01 AM
  #58
ttboost's Avatar
You need to find out what Tony wants you to log. Does he know you have the LWFW?
Old Feb 28, 2010 | 07:07 AM
  #59
jalmood's Avatar
I think he does, i sent him a list of all the parts that i have installed into my car before he sent me the flash, unless he forgot about it.
i hope that Tony chimes in again. All the parts i have in my car are mentioned in my signature.
Old Feb 28, 2010 | 07:17 AM
  #60
MBailey's Avatar
That sounds like a boost leak. Probably something not put back on tight enough.
