The Latest upgrade: TCU flash
Old Nov 12, 2009 | 02:04 PM
bmoores's Avatar
bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !bmoores Is a GOD !
Originally Posted by PAULIEWALNUTS
Ben thanks for your assessment,sounds like you need to turn up the boost, 143 through the traps is haulin a$$.
Haulin major ***. My Vbox 1/4 trap at the mile was 137.9. I've got a little ways to go and Anthony's car has a slightly different MAF setup. Still happy that i'm only starting to tap into the turbos though. C16 will give me another .2 bar. Any more than that and i'll have to start thinking about rods.
Old Nov 12, 2009 | 02:11 PM
Powell's Avatar
Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !Powell Is a GOD !
If timing is kept low, which most tuners do not do; you shouldn't have to worry about to much when turning up the boost. Remember I'm making my power at 1.75bar sustained on MS109 with a low amount of timing.
Old Nov 12, 2009 | 02:14 PM
BlackHorseTurbo's Avatar
BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !BlackHorseTurbo Is a GOD !
Originally Posted by bmoores
I predict a 7.0 60-130.
Very funny
Originally Posted by 007-911
Where are you getting the TCU flashed from? Are you rasing the rev limiter?
Vince, EVOMS is flashing the TCU for me. Rev limit is raised to 7250 in the Softronic flash already but it never shifts that late (the highest being 6800). EVOMS programming allows the TCU to take advantage of that raised limit and actually shift around 7k.
Originally Posted by MY996TT
I predict .2 or .3 second faster. The 7k rpm shifts feel quite good.
I think that is very reasonable.
Originally Posted by edelectra
who does tcu upgrades
EVOMS does 996's and 997's and I have heard Tym Switzer does 997's.
Todd do you think you could of gone 200 mph if you had a 6 speed? I am trying to see if the 20g's really make that much difference to the 18g's. The difference of 3 mph seems minimal (Todd 197 vs Ben 200)
I think I could have gone 200 with DR's.
Originally Posted by AdamW81
I believe EVOMS is the only one, its a fairly recent development.
Like I said, I think Switzer is also doing 997's.
Here is the conclusion we've come to Paulie. I pull on Todd after 130. The 20's have better top end thats about it. My numbers to 130 are comparable but when you consider i'm having to shift manually and rebuild boost each time that should indicate the slight power advantage over the 20's. Also i've only ran pretty moderate boost on the 20's. Running 1.55 - 1.6 bar is possible and that is where the 20's really shine. Mexicant's car went through the traps at 143 mph with 20's.
Right, after comparing data. Ben's 130-190 is more than a second quicker.
PAULIEWALNUTS's Avatar
PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !PAULIEWALNUTS Is a GOD !
Originally Posted by Powell
IMO if you want to do *** hauling it's time to ditch the tippy for a Powerglide and through Boost Logic "Powell" kit on and run low 9s all day long
That Chris Powell sure is a snappy young buck. Simmer down now.
Old Nov 12, 2009 | 02:33 PM
Powell's Avatar
You should see what I have in store next!
Old Nov 12, 2009 | 03:36 PM
Originally Posted by Shotcaller
Goodluck Todd
Keep update us!!!
Thanks, I will.
Old Nov 12, 2009 | 04:11 PM
007-911's Avatar
007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of007-911 has much to be proud of
I want to order this from EVOMS but Tony@EPL refused to raise the rev limiter to work with it.
Old Nov 12, 2009 | 04:22 PM
Interesting.. Tony knows whats best for your car. How is your car running now? Did you get to the track yet?
Old Nov 15, 2009 | 09:42 AM
Tony@epl's Avatar
Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !Tony@epl Is a GOD !
I never refused, just stated that I dont think its a good idea without proper testing and tuning.
Just a word of caution when upgrading TCU software to allow for a higher revlimit... make sure your tuner has actually "tuned" your DME calibration for the extra rpms range.... Im not just speaking of bumping the rpm, Im talking about fuel/spark/boost mapping.
Old Nov 15, 2009 | 09:53 AM
Good point Tony, I plan to datalog for Scott. Also, I don't plan to shift much higher than 6800-6900 as the 18g's are not effencient in high RPMs. But I'm looking forward to the results. IF I'm not happy, EVOMS will refund my money.
Old Nov 15, 2009 | 01:16 PM
MBailey's Avatar
Interesting way to look at the data. You should look at my 130-190 split
Old Nov 15, 2009 | 01:19 PM
robmd99's Avatar
robmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond reputerobmd99 has a reputation beyond repute
Bluey wants to Play with the "Powell" kit
Robert
Old Nov 15, 2009 | 02:56 PM
Mike, I just pulled the data from 130-190:
Ben 12.51
Mike 12.68
Todd 13.37
Old Nov 15, 2009 | 02:58 PM
Actually I was less than a second behind. 12.51 to 13.37.
Old Nov 15, 2009 | 04:00 PM
MBailey's Avatar
Ben 12.51
Mike 12.68
Todd 13.37
My data has Ben and me the other way around.
