diverter valves
Old Nov 15, 2009 | 02:38 AM
dynamic gt2's Avatar
dynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to beholddynamic gt2 is a splendid one to behold
diverter valves
worth it to replace the stock diverter valves
Thank you
Old Nov 15, 2009 | 03:46 AM
ShokWaveRider's Avatar
ShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to allShokWaveRider is a name known to all
Depends on your Target Boost pressure and if they are bad or not. They work for what they are designed for. IMHO I would not change them for the sake of it. Just because someone tells you to (and they will). If they are bad it is a different thing. I would not put the stock units back in this case, I would go for Side Vacuum Forge units from Forge themselves or Titan Motorsports. In addition I would also not replace the F Hose with a silicone one either. The stock F hose is good for 30psi and unless it is damaged, petrified or checked, I would clean it up and re-install it. Even if it was bad I would replace it with a stock F hose.
SWR
Thank you
Old Nov 15, 2009 | 10:20 AM
robertp's Avatar
robertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud ofrobertp has much to be proud of
I would think that a GT2 Gemballa already has aftermarket DV's.
White991TT
Mar 8, 2016 06:01 AM
sdg1871
Nov 22, 2015 07:27 PM
flewis763
Oct 4, 2015 04:14 PM
