Passenger window one touch up is not working...
Old Nov 15, 2009 | 03:14 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
Since i bought the car passenger window does not close with one touch...I tried a new switch without any luck...i also kept down switch for 10 sec in order to reprogram it again with no luck...any ideas?
Old Nov 15, 2009 | 03:55 PM
wross996TT's Avatar
Retraining the window:
1. hold the up button until the window is up and then for ten seconds
2. hold the down button until the window is down and then 10 seconds
unless you changed the motor...
Standardising the new power window motor
1. Switch on ignition.
2. Open door window completely by continuously actuating the power window operating button, and then close window. Press power window button until the window is closed and is switched off by the blockage detection function of the power window motor. Standardisation is then completed.
Old Nov 15, 2009 | 04:36 PM
Thank you...one touch for down operates fine...only for up does not work...i asked Porsche here and they told me that there are cars without auto up in passenger window...However i havent tried setting up a new window motor (maybe the previous owner did change the motor)...I will try it tomorrow...
Old Nov 15, 2009 | 06:50 PM
TXGold's Avatar
TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !TXGold Is a GOD !
Sounds like something a dealership would say. The above mentioned info should work. Good luck.
Old Nov 15, 2009 | 07:33 PM
WOODTSTER's Avatar
. Leave it to some dealers !
If you unhook your battery, or your battery goes dead, you lose this function, until you do as prescribed; hold it down, then hold it up and it should work fine.
MK
Old Nov 16, 2009 | 07:10 AM
a66cobra1's Avatar
a66cobra1 is a splendid one to beholda66cobra1 is a splendid one to beholda66cobra1 is a splendid one to beholda66cobra1 is a splendid one to beholda66cobra1 is a splendid one to beholda66cobra1 is a splendid one to beholda66cobra1 is a splendid one to behold
Great timing for your post, mine is doing the same thing. Will try today.
Now, if only I could fix my damn drivers headlamp issue. Ugh!
Rockinc1
Sep 30, 2015 06:44 PM
Wheeler
Sep 22, 2015 08:02 PM
BLKMGK
Sep 19, 2015 03:51 PM
