Upgraded Brakes Need Advice
Old Nov 17, 2009 | 10:55 PM
Turbo Fanatic's Avatar
I have the opportunity to pick up:
1. A set of 997 TT brakes $2,000 installed
2. 2nd Gen 996 TT Ceramics $5,000 installed
Any opinion on these setups? I understand both sets are similar to 996 GT3/GT2 brakes. 6 Pot calipers and 350mm fronts. Of course they are factory units so future parts, pads, etc.. are easy to get and the quality is assured.
Are these good prices? Would you do it? Which setup would you pick? $3,000 price difference is a LOT money.
Old Nov 17, 2009 | 11:13 PM
adam699's Avatar
adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !adam699 Is a GOD !
IMHO #1 sounds like a steal I'm not sure I'd go with the ceramics since replacement rotors are $$$ and most guys go with steel rotors anyway for tracking it seems which would pretty much bring you back to #1 anyway.
Old Nov 17, 2009 | 11:15 PM
OS Inspector's Avatar
OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !OS Inspector Is a GOD !
PCCB no way too expensive to replace
997TT brakes you should only use the front as the rear are too large and the 997 has a different brake bias then the 996 and will mess with the abs and the balance in braking.
a set of gt3 calipers n matching rotors would be a good idea or there is the BBk from Brembo.
Old Nov 17, 2009 | 11:54 PM
Thanks for the quick response. I have also read that the 997 TT rears offer too much rear brake bias on the 996. No offense but is there any proof of this? Sometimes these things get repeated over and over on the net and take a life of their own.
On a similar note, leaving stock 996TT rears and upgrading the fronts may result in too much front brake bias. This is all new to me, how does one go about making sure that the brakes are balanced front to rear? I suppose at the limit ABS would sort it out, but what about hard braking that does not lock any one or more tires?
Old Nov 18, 2009 | 01:06 AM
AlFromCalabasas's Avatar
AlFromCalabasas is a splendid one to beholdAlFromCalabasas is a splendid one to beholdAlFromCalabasas is a splendid one to beholdAlFromCalabasas is a splendid one to beholdAlFromCalabasas is a splendid one to beholdAlFromCalabasas is a splendid one to beholdAlFromCalabasas is a splendid one to behold
Ari,
I would just get the 996 GT3 / GT2 front brakes and call it a day. This is a very popular upgrade here.
-Alex
Old Nov 18, 2009 | 09:31 AM
landjet's Avatar
I replaced my brakes with the 996GT3 yellow brakes all around with 997TT 350mm discs. It was a direct bolt up. There is the same front braking bias that was there before, but now I use Pagid yellow pads up front and Pagid blacks on the rears to help put a little more bite in the rear to balance some of the front bias. Good luck with either direction you choose.
Old Nov 18, 2009 | 09:42 AM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
i have the same questions with you...i just bought both,front and rear 997TT brakes and want to install them both...has anyone done that?Normally if both are installed there should be no problem...
Jul 29, 2019 11:13 AM
LiquidElephant
Aug 27, 2015 06:17 PM
Steven997TT
Aug 27, 2015 02:56 PM
Sales@RSW
BMW //M
Aug 26, 2015 06:41 AM
The Oss
Aug 24, 2015 08:19 PM
