Accelerating problem
Old Nov 18, 2009 | 05:03 PM
skandalis447's Avatar
skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !skandalis447 Is a GOD !
I believe so Mark...when the last clutch slipped,revs went up and miles stay there...Now the car accelerates with surges like an earthquake between 4 and 5 krpm...but only there...
Old Nov 18, 2009 | 05:24 PM
art4iza's Avatar
art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !art4iza Is a GOD !
MAF possible but PSM code is off then I say plugs....clutch slipping would bounce the rev. limiter in 4th gear
Old Nov 18, 2009 | 05:48 PM
unvmy996's Avatar
i woudl change the plugs and while ur down there i would get new coils also.. will save you future headeaches, i reaplaced mine the car only had 17k on it and most of them had cracks .
Old Nov 18, 2009 | 06:51 PM
plugs....
if you have a boost controller turn down the boost to minimum and your problem will go away usually... and that is the plugs...
2001 996TT 3.6L and stock ECU
9.66
seconds @ 147.76 mph 1/4 mile
click to view
Old Nov 19, 2009 | 01:00 AM
Yes Mark...at 0,8 or even 1,2 there is no problem...only at high boost...you think i should change coils as well?Should i get OEM or aftermarket?
Old Nov 27, 2009 | 12:21 PM
Problem solved...It was plugs...I checked coils as well but they were perfect...Weird their part number starts with 997...Maybe previous owner changed them?Car runs fine and accelerates really fast...next days i will try to beat my personal 60-130 time...(waiting for weather to cool down we have 21 deg celsious here...)
Old Nov 27, 2009 | 02:15 PM
landjet's Avatar
The coil packs must have been changed because the part number now, has been superseded to a 997 parts number.
PV=nRT.
Sep 9, 2022 06:06 PM
ModBargains
Bentley Vendor Classifieds
Oct 13, 2015 03:42 PM
ModBargains
Lotus Vendor Classifieds
ModBargains
McLaren Vendor Classifieds
Oct 13, 2015 03:41 PM
ModBargains
Oct 13, 2015 03:40 PM
