PCCB e-brake on aluminum hats?
Old Nov 24, 2009 | 01:48 PM
smdubovsky's Avatar
smdubovsky is infamous around these parts
I was chatting w/ someone about aluminum hats on race car brakes and how they can't be used w/ e-brakes. Somewhere in our conversation it dawned on me the last time I had my pccb rotors off, both F&R heats are aluminum (I'm 95% sure). The rears don't have a steel liner for the e-brakes. How the heck do they get away w/ that? They'll hold on a hill, but if you ever pulled it at speed (which is why its called an emergency brake) the pads will load up and stop working? Is the hat embedded, cast w/, plated w/ something that allows it to work?
Im really curious...
Old Nov 24, 2009 | 03:40 PM
Mikelly's Avatar
Actually I had a wilwood brake setup on the rear of a c5 corvette that used the e-brake setup that is very similar to the Porsche ebrake system. It worked just fine and the wilwood rear hat was aluminum!
Mike
Old Nov 24, 2009 | 05:17 PM
smdubovsky's Avatar
An aftermarket wilwood setup even though it worked fine, prob wasn't tested to federal standards?
Though, doing some more digging the best article I can come up w/ is (NTSA Title 49):
http://tinyurl.com/ykrjdok
They don't list a moving test. Just has to hold on a 20% grade and not break when hit @ 2.5mph.
Porsche doesn't list different e-brake shoes for pccb. I still wonder if you grabbed it at moderate speed if it'd gum up and stop working. Just doesn't take much heat to soften aluminum. I know mtn bikes once tried to use aluminum rotors and were somewhat sucessful w/ special pads. They aren't around any longer though
Old Nov 25, 2009 | 05:05 PM
oak's Avatar
oak
pccb hats are stainless steel.
Kai@ELITEMS
996 Turbo Vendor Classifieds
Nov 25, 2015 06:44 AM
Kai@ELITEMS
Nov 25, 2015 06:40 AM
Kai@ELITEMS
997 Turbo Vendor Classifieds
Nov 25, 2015 06:39 AM
Kai@ELITEMS
996 Vendor Classifieds
Nov 25, 2015 06:32 AM
Kai@ELITEMS
997 Vendor Classifieds
